Configure the NFS protocol with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to authenticate NFS clients to access data on the SVM.
Edit NFS settings
You can use System Manager to edit the NFS settings such as enabling or disabling NFSv3, NFSv4, and NFSv4.1, enabling or disabling read and write delegations for NFSv4 clients, and enabling NFSv4 ACLs. You can also edit the default Windows user.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Protocols pane, click NFS.
  4. In the NFS window, click Edit.
  5. In the Edit NFS Settings dialog box, make the required changes.
  6. Click Save and Close.
NFS window
You can use the NFS window to display and configure your NFS settings.
  • Server Status
    Displays the status of the NFS service. The service is enabled if the NFS protocol is configured on the storage virtual machine (SVM).
    Note
    If you have upgraded to ONTAP 8.3 or later from an NFS-enabled storage system running Data ONTAP 8.1.x, the NFS service is enabled in ONTAP 8.3 or later. However, you must enable support for NFSv3 or NFSv4 because NFSv2 is no longer supported.
Command buttons
  • Enable
    Enables the NFS service.
  • Disable
    Disables the NFS service.
  • Edit
    Opens the Edit NFS Settings dialog box, which enables you to edit NFS settings.
  • Refresh
    Updates the information in the window.
Related information
