Manage mirror relationships with System Manager - ONTAP 9.7 and earlier
Contributors netapp-maireadn netapp-lenida netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage mirror relationships. You can update, create, quiesce, initialize, reestablish, delete and edit mirror relationships in addition to resuming quiesced mirror relationships.
Delete relationships
You can use System Manager to delete a mirror relationship and permanently end the mirror relationship between the source and destination volumes. When a mirror relationship is deleted, the base Snapshot copy on the source volume is deleted.
About this task
It is a best practice to break the mirror relationship before deleting the relationship.
Steps
  1. Click Protection > Volume Relationships.
  2. Select the mirror relationship that you want to delete and click Delete.
  3. Select the confirmation check boxes to delete the mirror relationship and to release the base Snapshot copies, and then click Delete.
Results
The relationship is deleted, and the base Snapshot copy on the source volume is deleted.
Resynchronize relationships
You can use System Manager to reestablish a mirror relationship that was broken earlier. You can perform a resynchronization operation to recover from a disaster that disabled the source volume.
Before you begin
The source cluster and destination cluster and the source SVM and destination SVM must be in peer relationships.
About this task
  • When you perform a resynchronization operation, the contents on the mirror destination are overwritten by the contents on the source volume.
    Note
    • For SnapLock compliance volumes, all data changes in the active file system with reference to the common Snapshot copy are preserved in a locked Snapshot copy until the expiry time that is set for the current volume.
      If the volume expiry time is in the past or has not been set, then the Snapshot copy and the common Snapshot copy are locked for a duration of 30 days. All of the intermediate Snapshot copies between the common Snapshot copy and the latest locked Snapshot copy are deleted.
    • For all volumes other than SnapLock compliance volumes, the resynchronization operation might cause loss of newer data that is written to the destination volume after the base Snapshot copy was created.
  • If the Last Transfer Error field in the Protection window recommends a resynchronization operation, you must first break the relationship, and then perform the resynchronization operation.
Steps
  2. Select the mirror relationship that you want to resynchronize.
  3. Click Operations > Resync.
  4. Select the confirmation checkbox, and then click Resync.
Resume quiesced relationships
You can use System Manager to resume a quiesced mirror relationship. When you resume the relationship, normal data transfer to the mirror destination is resumed and all the mirror activities are restarted.
About this task
If you have quiesced a broken mirror relationship from the command-line interface (CLI), you cannot resume the relationship from System Manager. You must use the CLI to resume the relationship.
Steps
  2. Select the mirror relationship that you want to resume.
  3. Click Operations > Resume.
  4. Select the confirmation check box and click Resume.
Results
Data transfer to the mirror destination resumes for the selected mirror relationship.
Update relationships
You can use System Manager to initiate an unscheduled mirror update of the destination. You might have to perform a manual update to prevent data loss due to an upcoming power outage, scheduled maintenance, or data migration.
Before you begin
The mirror relationship must be in a Snapmirrored state.
Steps
  2. Select the mirror relationship for which you want to update the data, and click Operations > Update.
  3. Choose one of the following options:
    • Select On demand to perform an incremental transfer from the recent common Snapshot copy between the source and destination volumes.
    • Select Select Snapshot copy and specify the Snapshot copy that you want to transfer.
  4. Optional: Select Limit transfer bandwidth to to limit the network bandwidth used for transfers and specify the maximum transfer speed.
  5. Click Update.
  6. Verify the transfer status in the Details tab.
Quiesce relationships
You can use System Manager to quiesce a mirror destination to stabilize it before creating a Snapshot copy. The quiesce operation enables active mirror transfers to finish and disables future transfers for the mirroring relationship.
About this task
You can quiesce only mirror relationships that are in the Snapmirrored state.
Steps
  2. Select the mirror relationship that you want to quiesce.
  3. Click Operations > Quiesce.
  4. Select the confirmation check box and click Quiesce.
Initialize relationships
When you start a mirror relationship, you must initialize that relationship. Initializing a relationship consists of a complete baseline transfer of data from the source volume to the destination. You can use System Manager to initialize a mirror relationship if you have not already initialized the relationship while creating it.
Steps
  2. Select the mirror relationship that you want to initialize.
  3. Click Operations > Initialize.
  4. Select the confirmation check box and click Initialize.
  5. Verify the status of the mirror relationship in the Protection window.
Results
A Snapshot copy is created and transferred to the destination. This Snapshot copy is used as a baseline for subsequent incremental Snapshot copies.
Edit relationships
You can use System Manager to edit a mirror relationship either by selecting an existing policy or schedule in the cluster, or by creating a policy or schedule.
About this task
  • You cannot edit a mirror relationship that is created between a volume in Data ONTAP 8.2.1 and a volume in ONTAP 8.3 or later.
  • You cannot edit the parameters of an existing policy or schedule.
  • You can modify the relationship type of a version-flexible mirror relationship, vault relationship, or mirror and vault relationship by modifying the policy type.
Steps
  2. Select the mirror relationship for which you want to modify the policy or schedule, and then click Edit.
  3. In the Edit Relationship dialog box, select an existing policy or create a policy:
    If you want to…​ Do the following…​
    Select an existing policy
    Click Browse, and then select an existing policy.
    Create a policy
    1. Click Create Policy.
    2. Specify a name for the policy.
    3. Set the priority for scheduled transfers.
      Low indicates that the transfer has the least priority and is usually scheduled after normal priority transfers. By default, the priority is set to Normal.
    4. Select the Transfer All Source Snapshot Copies check box to include the “all_source_snapshots” rule to the mirror policy, which enables you to back up all of the Snapshot copies from the source volume.
    5. Select the Enable Network Compression check box to compress the data that is being transferred.
    6. Click Create.
  4. Specify a schedule for the relationship:
    If…​ Do the following…​
    You want to assign an existing schedule
    From the list of schedules, select an existing schedule.
    You want to create a schedule
    1. Click Create Schedule.
    2. Specify a name for the schedule.
    3. Select either Basic or Advanced.
      • Basic specifies only the day of the week, time, and the transfer interval.
      • Advanced creates a cron-style schedule.
    4. Click Create.
    You do not want to assign a schedule
    Select None.
  5. Click OK to save the changes.
Create mirror relationships from a destination SVM
You can use System Manager to create a mirror relationship from the destination storage virtual machine (SVM) and to assign a policy and schedule to the mirror relationship. The mirror copy enables quick availability of data if the data on the source volume is corrupted or lost.
Before you begin
  • The source cluster must be running ONTAP 8.2.2 or later.
  • The SnapMirror license must be enabled on the source cluster and destination cluster.
    Note
    For some platforms, it is not mandatory for the source cluster to have the SnapMirror license enabled if the destination cluster has the SnapMirror license and Data Protection Optimization (DPO) license enabled.
  • While mirroring a volume, if you select a SnapLock volume as the source, then the SnapMirror license and SnapLock license must be installed on the destination cluster.
  • The source cluster and destination cluster must be in a healthy peer relationship.
  • The destination SVM must have space available.
  • A source volume of type read/write (rw) must exist.
  • The FlexVol volumes must be online and must be of type read/write.
  • The SnapLock aggregate type must be of the same type.
  • If you are connecting from a cluster running ONTAP 9.2 or earlier to a remote cluster on which Security Assertion Markup Language (SAML) authentication is enabled, password-based authentication must be enabled on the remote cluster.
About this task
  • System Manager does not support a cascade relationship.
    For example, a destination volume in a relationship cannot be the source volume in another relationship.
  • You cannot create a mirror relationship between a sync-source SVM and a sync-destination SVM in a MetroCluster configuration.
  • You can create a mirror relationship between sync-source SVMs in a MetroCluster configuration.
  • You can create a mirror relationship from a volume on a sync-source SVM to a volume on a data-serving SVM.
  • You can create a mirror relationship from a volume on a data-serving SVM to a data protection (DP) volume on a sync-source SVM.
  • You can create a mirror relationship between SnapLock volumes of the same type only.
    For example, if the source volume is a SnapLock Enterprise volume, then the destination volume must also be a SnapLock Enterprise volume. You must ensure that the destination SVM has aggregates of the same SnapLock type available.
  • The destination volume that is created for a mirror relationship is not thin provisioned.
  • A maximum of 25 volumes can be protected in one selection.
  • You cannot create a mirror relationship between SnapLock volumes if the destination cluster is running a version of ONTAP that is older than the ONTAP version that the source cluster is running.
Steps
  2. In the Volume Relationships window, click Create.
  3. In the Browse SVM dialog box, select an SVM for the destination volume.
  4. In the Create Protection Relationship dialog box, select Mirror from the Relationship Type drop-down list.
  5. Specify the cluster, the SVM, and the source volume.
    If the specified cluster is running a version of ONTAP software earlier than ONTAP 9.3, then only peered SVMs are listed. If the specified cluster is running ONTAP 9.3 or later, peered SVMs and permitted SVMs are listed.
  6. For FlexVol volumes, specify a volume name suffix.
    The volume name suffix is appended to the source volume names to generate the destination volume names.
  7. Click Browse, and then change the mirror policy.
  8. Select a schedule for the relationship from the list of existing schedules.
  9. Select Initialize Relationship to initialize the mirror relationship.
  10. Enable FabricPool-enabled aggregates, and then select an appropriate tiering policy.
  11. Click Create.
Results
If you chose to create a destination volume, a destination volume of type dp is created, with the language attribute set to match the language attribute of the source volume.
A mirror relationship is created between the source volume and the destination volume. The base Snapshot copy is transferred to the destination volume if you have opted to initialize the relationship.
Reverse resynchronizing mirror relationships
You can use System Manager to reestablish a mirror relationship that was previously broken. In a reverse resynchronization operation, you reverse the functions of the source volume and destination volume.
Before you begin
The source volume must be online.
About this task
  • You can use the destination volume to serve data while you repair or replace the source volume, update the source volume, and reestablish the original configuration of the systems.
  • When you perform reverse resynchronization, the contents on the mirror source are overwritten by the contents on the destination volume.
    Note
    • For all volumes other than SnapLock compliance volumes, the resynchronization operation might cause loss of newer data that is written to the source volume after the base Snapshot copy was created.
  • When you perform reverse resynchronization, the mirror policy of the relationship is set to DPDefault, and the mirror schedule is set to None.
Steps
  2. Select the mirror relationship that you want to reverse.
  3. Click Operations > Reverse Resync.
  4. Select the confirmation checkbox, and then click Reverse Resync.
Related information
