Display the status of cluster replication rings
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
You can display the status of cluster replication rings to help you diagnose cluster-wide problems. If your cluster is experiencing problems, support personnel might ask you to perform this task to assist with troubleshooting efforts.
Steps
To display the status of cluster replication rings, use the
cluster ring show
command at the advanced privilege level.
Example of displaying cluster ring-replication status
The following example displays the status of the VLDB replication ring on a node named node0:
cluster1::> set -privilege advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by support personnel. Do you wish to continue? (y or n): y cluster1::*> cluster ring show -node node0 -unitname vldb Node: node0 Unit Name: vldb Status: master Epoch: 5 Master Node: node0 Local Node: node0 DB Epoch: 5 DB Transaction: 56 Number Online: 4 RDB UUID: e492d2c1-fc50-11e1-bae3-123478563412
