Download NetApp license files (NLF) from NetApp Support Site
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
If your system is running ONTAP 9.10.1 or later, you can upgrade the bundle license files on existing systems by downloading the NLF for ONTAP One or ONTAP Core from the NetApp Support Site.
The SnapMirror Cloud and S3 SnapMirror licenses are not included with ONTAP One. They are part of the ONTAP One Compatibility bundle, which you can get for free if you have ONTAP One and request separately. |
You can download ONTAP One license files for systems with existing NetApp license file bundles and for systems with 28-character license keys that have been converted to NetApp license files on systems running ONTAP 9.10.1 and later. For a fee, you can also upgrade systems from ONTAP Base to ONTAP One.
Contact your NetApp sales team and request the license file bundle you want to upgrade or convert (for example, ONTAP Base to ONTAP One, or Core Bundle and Data Protection bundle to ONTAP One).
When your request is processed, you will receive an email from netappsw@netapp.com with the subject “NetApp Software Licensing Notification for SO# [SO Number]” and the email will include a PDF attachment that includes your license serial number.
Log in to the NetApp Support Site.
Select Systems > Software Licenses.
From the menu, choose Serial Number, enter the serial number you received, and click New Search.
Locate the license bundle you want to convert.
Click Get NetApp License File for each license bundle and download the NLFs when they're available.
Install the ONTAP One file.
From the menu, choose Serial Number, enter the system serial number, and click New Search.
Locate the license you want to convert, and in the Eligibility column click Check.
In the Check Eligibility form, click Generate Licenses for 9.10.x and later.
Close the Check Eligibility form.
You will need to wait at least 2 hours for the licenses to generate.
Repeat Steps 1 through 3.
Locate the ONTAP One license, click Get NetApp License File, and choose the delivery method.
