Manage AutoSupport settings with System Manager
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can use System Manager to manage the settings for your AutoSupport account.
You can perform the following procedures:
View AutoSupport settings
You can use System Manager to view the settings for your AutoSupport account.
In System Manager, click Cluster > Settings.
In the AutoSupport section, the following information is displayed:
Status
Transport protocol
Proxy server
From email address
In the AutoSupport section, select , then select More Options.
Additional information is displayed about the AutoSupport connection and email settings. Also, the transfer history of messages is listed.
Generate and send AutoSupport data
In System Manager, you can initiate the generation of AutoSupport messages and choose from which cluster node or nodes the data is collected.
In System Manager, select Cluster > Settings.
In the AutoSupport section, select , then select Generate and Send.
Enter a subject.
Select the check box under Collect Data From to specify the nodes from which to collect the data.
Test the connection to AutoSupport
From System Manager, you can send a test message to verify the connection to AutoSupport.
In the AutoSupport section, select , then select Test Connectivity.
Enter a subject for the message.
Enable or disable AutoSupport
AutoSupport delivers proven business benefits to NetApp customers, including proactive identification of possible configuration issues and accelerated support case resolution. AutoSupport is enabled by default in new systems. If required, you can use System Manager to disable the ability of AutoSupport to monitor the health of your storage system and send you notification messages. You can enable AutoSupport again after it has been disabled.
Before you disable AutoSupport, you should be aware that you are turning off the NetApp call-home system and you’ll lose the following benefits:
Health Monitoring: AutoSupport monitors the health of your storage system and sends notifications to technical support and your internal support organization.
Automation: AutoSupport automates the reporting of support cases. Most support cases are opened automatically before customers realize there’s a problem.
Faster resolution: Systems sending AutoSupport data have their support cases resolved in half of the time compared to cases for systems that not sending AutoSupport data.
Faster upgrades: AutoSupport powers customer self-service workflows, such as version upgrades, add-ons, renewals, and firmware update automation in System Manager.
More functions: Certain functions in other tools work only when AutoSupport is enabled, for example, some workflows in BlueXP.
Select Cluster > Settings.
In the AutoSupport section, select , then select Disable.
If you want to enable AutoSupport again, in the AutoSupport section, select , then select Enable.
Suppress the generation of support cases
Beginning with ONTAP 9.10.1, you can use System Manager to send a request to AutoSupport to suppress the generation of support cases.
To suppress the generation of support cases, you specify the nodes and number of hours for which you want the suppression to occur.
Suppressing support cases can be especially helpful if you do not want AutoSupport to create automated cases while you are performing maintenance on your systems.
In the AutoSupport section, select , then select Suppress Support Case Generation.
Enter the number of hours that you want the suppression to occur.
Select the nodes for which you want the suppression to occur.
Resume the generation of support cases
Beginning with ONTAP 9.10.1, you can use System Manager to resume the generation of support cases from AutoSupport if it has been suppressed.
In the AutoSupport section, select , then select Resume Support Case Generation.
Select the nodes for which you want the generation to resume.
Edit AutoSupport settings
You can use System Manager to modify the connection and email settings for your AutoSupport account.
In the Connections section or the Email section, select to modify the settings for either section.
