Manage protection policies with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife netapp-maireadn
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create, edit, and delete protection policies.
Create protection policies
You can use System Manager to create cluster-level asynchronous mirror policies, vault policies, or mirror and vault policies, and to apply these policies to a cluster-level data protection relationship.
Steps
  1. Click Protection > Protection Policies.
  2. Click Create.
  3. In the Create Policy dialog box, select the type of policy that you want to create.
  4. Specify the policy name and transfer priority.
    Low indicates that the transfer has the lowest priority. Low priority transfers are usually scheduled after normal priority transfers. By default, the transfer priority is set to Normal.
  5. Optional: Select the Enable Network Compression check box to compress the data that is being transferred during a data transfer.
  6. Optional: For an asynchronous mirror policy, select the Transfer All Source Snapshot Copies check box to include the “all_source_snapshots” rule to the mirror policy, which backs up all of the Snapshot copies from the source volume.
  7. Optional: Click Add Comments to add additional comments for the policy.
  8. For a vault policy or mirror vault policy, specify a SnapMirror label and a destination retention count.
  9. Click Create.
Protection Policies window
You can use the Protection Policies window to create, manage, and display information about mirror, vault, and mirror vault policies.
Command buttons
  • Create
    Opens the Create Policy dialog box, which enables you to create a mirror, vault, or mirror vault policy.
  • Edit
    Opens the Edit Policy dialog box, which enables you to edit a policy.
  • Delete
    Opens the Delete Policy dialog box, which enables you to delete a policy.
  • Refresh
    Updates the information in the window.
Protection policies list
  • Name
    Displays the name of the protection policy.
  • Type
    Displays the policy type, which can be Vault, Mirror Vault, or Asynchronous Mirror.
  • Comment
    Displays the description specified for the policy.
  • Transfer Priority
    Displays the data transfer priority, such as Normal or Low.
Details area
  • Policy Details tab
    Displays details of the protection policy, such as the user who created the policy, number of rules, retention count, and status of network compression.
  • Policy Rules tab
    Displays details of the rules that are applied to the policy. The Policy Rules tab is displayed only if the selected policy contains rules.
