Delete FlexGroup volumes with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to delete a FlexGroup volume when you no longer require the FlexGroup volume.
Before you begin
  • The junction path of the FlexGroup volume must be unmounted.
  • The FlexGroup volume must be offline.
About this task
System Manager does not support constituent level of management for FlexGroup volumes.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the FlexGroup volume that you want to delete, and then click Delete.
  4. Select the confirmation check box, and then click OK.
Related information
