Storage service definitions for System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
ONTAP System Manager classic (available in ONTAP 9.7 and earlier) includes predefined storage services that are mapped to corresponding minimum performance factors.
The actual set of storage services available in a cluster or SVM is determined by the type of storage that makes up an aggregate in the SVM.
The following table shows how the minimum performance factors are mapped to the predefined storage services:
Storage service Expected IOPS (SLA) Peak IOPS (SLO) Minimum volume IOPS Estimated latency Are expected IOPS enforced?
value
128 per TB
512 per TB
75
17 ms
On AFF: Yes
Otherwise: No
performance
2048 per TB
4096 per TB
500
2 ms
Yes
extreme
6144 per TB
12288 per TB
1000
1 ms
Yes
The following table defines the available storage service level for each type of media or node:
Media or node Available storage service level
Disk
value
Virtual machine disk
value
FlexArray LUN
value
Hybrid
value
Capacity-optimized Flash
value
Solid-state drive (SSD) - non-AFF
value
Performance-optimized Flash - SSD (AFF)
extreme, performance, value
