NVMe/FC Host Configuration for Oracle Linux 7.7 with ONTAP
You can configure NVMe over Fibre Channel (NVMe/FC) on initiator hosts running Oracle Linux 7.7 and ONTAP as the target.
Supportability
Beginning with ONTAP 9.6, NVMe/FC is supported for Oracle Linux 7.7. The Oracle Linux 7.7 host can run both NVMe and SCSI traffic through the same fibre channel initiator adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers. For the current list of supported configurations see the Interoperability Matrix Tool.
You can use the configuration settings provided in this procedure to configure cloud clients connected to Cloud Volumes ONTAP and Amazon FSx for ONTAP. |
Known limitations
Native NVMe/FC auto-connect scripts are not available in the nvme-cli package.
You can use the HBA vendor provided external auto-connect scripts. -
By default, round-robin load balancing is not enabled.
You must write a udev rule to enable this functionality. Steps are provided in the section on Enabling NVMe/FC on OL 7.7. -
SAN booting using the NVMe-oF protocol is currently not supported.
Enabling NVMe on OL 7.7
Ensure the default Oracle Linux 7.7 kernel is installed.
Reboot the host and verify that it boots into specified OL 7.7 kernel.
# uname -r 4.14.35-1902.9.2.el7uek
Upgrade to the nvme-cli-1.8.1-3.el7 package.
# rpm -qa|grep nvme-cli nvme-cli-1.8.1-3.el7.x86_64
Add the string below as a separate udev rule at
/lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules. This enables round-robin load balancing for NVMe multipath.# Enable round-robin for NetApp ONTAP ACTION==”add”, SUBSYSTEM==”nvme-subsystem”, ATTR{model}==”NetApp ONTAP Controller”, ATTR{iopolicy}=”round-robin -
On the OL 7.7 host, check the host NQN string at
/etc/nvme/hostnqnand verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array.# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
*> vserver nvme subsystem host show -vserver vs_nvme_10 Vserver Subsystem Host NQN ------- --------- -------------------------------------- ----------- ol_157_nvme_ss_10_0 nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
If the host NQN strings do not match, you should use the vserver modify command to update the host NQN string on your corresponding ONTAP array subsystem to match to host NQN string from /etc/nvme/hostnqn on the host.
Reboot the host.
Configuring the Broadcom FC Adapter for NVMe/FC
Verify that you are using a supported adapter. For the current list of supported adapters see the Interoperability Matrix Tool.
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Copy and install the Broadcom outbox auto-connect scripts package.
# rpm -ivh nvmefc-connect-12.4.65.0-1.noarch.rpm
Reboot the host.
Verify that you are using the recommended Broadcom lpfc firmware, native inbox driver and outbox auto-connect package versions. For a list of supported versions, see the Interoperability Matrix Tool.
# cat /sys/class/scsi_host/host*/fwrev 12.4.243.17, sil-4.2.c 12.4.243.17, sil-4.2.c # cat /sys/module/lpfc/version 0:12.0.0.10 # rpm -qa | grep nvmefc nvmefc-connect-12.4.65.0-1.noarch
Verify that lpfc_enable_fc4_type is set to 3.
# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running.
# cat /sys/class/fc_host/host*/port_name 0x10000090fae0ec61 0x10000090fae0ec62
# cat /sys/class/fc_host/host*/port_state Online Online
Verify that the NVMe/FC initiator ports are enabled, running and able to see the target LIFs.
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 NVME 2947 SCSI 2977 ELS 250 NVME LPORT lpfc0 WWPN x10000090fae0ec61 WWNN x20000090fae0ec61 DID x012000 ONLINE NVME RPORT WWPN x202d00a098c80f09 WWNN x202c00a098c80f09 DID x010201 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203100a098c80f09 WWNN x202c00a098c80f09 DID x010601 TARGET DISCSRVC ONLINE NVME Statistics …
Validating NVMe/FC
Verify the following NVMe/FC settings.
# cat /sys/module/nvme_core/parameters/multipath Y # cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created.
# nvme list Node SN Model Namespace Usage Format FW Rev ---------------- -------------------- ----------------------- /dev/nvme0n1 80BADBKnB/JvAAAAAAAC NetApp ONTAP Controller 1 53.69 GB / 53.69 GB 4 KiB + 0 B FFFFFFFF
Verify the status of the ANA paths.
# nvme list-subsys/dev/nvme0n1 Nvme-subsysf0 – NQN=nqn.1992-08.com.netapp:sn.341541339b9511e8a9b500a098c80f09:subsystem.ol_157_nvme_ss_10_0 \ +- nvme0 fc traddr=nn-0x202c00a098c80f09:pn-0x202d00a098c80f09 host_traddr=nn-0x20000090fae0ec61:pn-0x10000090fae0ec61 live optimized +- nvme1 fc traddr=nn-0x207300a098dfdd91:pn-0x207600a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x207300a098dfdd91:pn-0x207500a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x207300a098dfdd91:pn-0x207700a098dfdd91 host traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live inaccessible
Verify the NetApp plug-in for ONTAP devices.
# nvme netapp ontapdevices -o column Device Vserver Namespace Path NSID UUID Size ------- -------- ------------------------- ------ ----- ----- /dev/nvme0n1 vs_nvme_10 /vol/rhel_141_vol_10_0/ol_157_ns_10_0 1 55baf453-f629-4a18-9364-b6aee3f50dad 53.69GB # nvme netapp ontapdevices -o json { "ONTAPdevices" : [ { Device" : "/dev/nvme0n1", "Vserver" : "vs_nvme_10", "Namespace_Path" : "/vol/rhel_141_vol_10_0/ol_157_ns_10_0", "NSID" : 1, "UUID" : "55baf453-f629-4a18-9364-b6aee3f50dad", "Size" : "53.69GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 13107200 } ]
Enabling 1MB I/O size for Broadcom NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
LPFC verbose logging
Set the lpfc driver for NVMe/FC.
Set the
lpfc_log_verbosedriver setting to any of the following values to log NVMe/FC events.#define LOG_NVME 0x00100000 /* NVME general events. */ #define LOG_NVME_DISC 0x00200000 /* NVME Discovery/Connect events. */ #define LOG_NVME_ABTS 0x00400000 /* NVME ABTS events. */ #define LOG_NVME_IOERR 0x00800000 /* NVME IO Error events. */
After setting the values, run the
dracut-fcommand and reboot the host. -
Verify the settings.
# cat /etc/modprobe.d/lpfc.conf options lpfc lpfc_log_verbose=0xf00083 # cat /sys/module/lpfc/parameters/lpfc_log_verbose 15728771
