ONTAP SAN Host Utilities
Configure RHEL 7.5 for FCP and iSCSI with ONTAP storage
Contributors netapp-pcarriga netapp-ranuk netapp-sdaffy netapp-aherbin netapp-sarajane netapp-aoife netapp-reenu netapp-madhulik
The Linux Host Utilities software provides management and diagnostic tools for Linux hosts that are connected to ONTAP storage. When you install the Linux Host Utilities on a Red Hat Enterprise Linux (RHEL) 7.5 host, you can use the Host Utilities to help you manage FCP and iSCSI protocol operations with ONTAP LUNs.
Note You don't need to manually configure Kernel-based Virtual Machine (KVM) settings because ONTAP LUNs are automatically mapped to the hypervisor.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot LUN and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Install the Linux Host Utilities
NetApp strongly recommends installing the Linux Host Utilities to support ONTAP LUN management and assist technical support with gathering configuration data.
Note Installing the Linux Host Utilities doesn't change any host timeout settings on your Linux host.
Step 3: Confirm the multipath configuration for your host
You can use multipathing with RHEL 7.5 to manage ONTAP LUNs.
To ensure that multipathing is configured correctly for your host, verify that the /etc/multipath.conf file is defined and that you have the NetApp recommended settings configured for your ONTAP LUNs.
Steps
  1. Verify that the /etc/multipath.conf file exists:
    ls /etc/multipath.conf
    If the file doesn't exist, create an empty, zero-byte file:
    touch /etc/multipath.conf
  2. The first time the multipath.conf file is created, you might need to enable and start the multipath services to load the recommended settings:
    systemctl enable multipathd
    systemctl start multipathd
  3. Each time you boot the host, the empty /etc/multipath.conf zero-byte file automatically loads the NetApp recommended host multipath parameters as the default settings. You shouldn't need to make changes to the /etc/multipath.conf file for your host because the host operating system is compiled with the multipath parameters that recognize and manage ONTAP LUNs correctly.
    The following table shows the native Linux OS compiled multipath parameter settings for ONTAP LUNs.
    Show parameter settings
    Parameter Setting
    detect_prio
    yes
    dev_loss_tmo
    "infinity"
    failback
    immediate
    fast_io_fail_tmo
    5
    features
    "3 queue_if_no_path pg_init_retries 50"
    flush_on_last_del
    "yes"
    hardware_handler
    "0"
    no_path_retry
    queue
    path_checker
    "tur"
    path_grouping_policy
    "group_by_prio"
    path_selector
    "service-time 0"
    polling_interval
    5
    prio
    "ontap"
    product
    LUN.*
    retain_attached_hw_handler
    yes
    rr_weight
    "uniform"
    user_friendly_names
    no
    vendor
    NETAPP
  4. Verify the parameter settings and path status for your ONTAP LUNs:
    multipath -ll
    The default multipath parameters support ASA, AFF, and FAS configurations. In these configurations, a single ONTAP LUN shouldn't require more than four paths. Having more than four paths can cause problems during a storage failure.
    The following example outputs show the correct parameter settings and path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
    ASA configuration
    An ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
    # multipath -ll
    3600a09803831347657244e527766394e dm-5 NETAPP,LUN C-Mode
    size=80G features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
    `-+- policy='service-time 0' prio=50 status=active
      |- 3:0:7:9    sdco 69:192  active ready running
      |- 3:0:8:9    sddi 71:0    active ready running
      |- 14:0:8:9   sdjq 65:320  active ready running
      `- 14:0:7:9   sdiw 8:256   active ready running
    AFF or FAS configuration
    An AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
    The following example displays the output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
    # multipath -ll
    | |- 3:0:3:0    sdd  8:48    active ready running
    | |- 3:0:4:0    sdx  65:112  active ready running
    `-+- policy='service-time 0' prio=10 status=enabled
      |- 14:0:2:0   sdfk 130:96  active ready running
      `- 14:0:5:0   sdgz 132:240 active ready running
Step 4: Optionally, exclude a device from multipathing
If required, you can exclude a device from multipathing by adding the WWID for the unwanted device to the "blacklist" stanza for the multipath.conf file.
Steps
  1. Determine the WWID:
    /lib/udev/scsi_id -gud /dev/sda
    "sda" is the local SCSI disk that you want to add to the blacklist.
    An example WWID is 360030057024d0730239134810c0cb833.
  2. Add the WWID to the "blacklist" stanza:
    blacklist {
    	     wwid   360030057024d0730239134810c0cb833
            devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
            devnode "^hd[a-z]"
            devnode "^cciss.*"
Step 5: Customize multipath parameters for ONTAP LUNs
If your host is connected to LUNs from other vendors and any of the multipath parameter settings are overridden, you need to correct them by adding stanzas later in the multipath.conf file that apply specifically to ONTAP LUNs. If you don't do this, the ONTAP LUNs might not work as expected.
Check your /etc/multipath.conf file, especially in the defaults section, for settings that might be overriding the default settings for multipath parameters.
Caution You shouldn't override the recommended parameter settings for ONTAP LUNs. These settings are required for optimal performance of your host configuration. Contact NetApp support, your OS vendor, or both for more information.
The following example shows how to correct an overridden default. In this example, the multipath.conf file defines values for path_checker and no_path_retry that aren't compatible with ONTAP LUNs, and you can't remove these parameters because ONTAP storage arrays are still attached to the host. Instead, you correct the values for path_checker and no_path_retry by adding a device stanza to the multipath.conf file that applies specifically to the ONTAP LUNs.
Show example
defaults {
   path_checker      readsector0
   no_path_retry     fail
devices {
   device {
      vendor          "NETAPP"
      product         "LUN"
      no_path_retry   queue
      path_checker    tur
Step 6: Review the known issues
The RHEL 7.5 with ONTAP storage release has the following known issues:
NetApp Bug ID Title Description
1440718
If you unmap or map a LUN without performing a SCSI rescan, it might lead to data corruption on the host.
When you set the 'disable_changed_wwids' multipath configuration parameter to YES, it disables access to the path device in the event of a WWID change. Multipath will disable access to the path device until the WWID of the path is restored to the WWID of the multipath device. To learn more, see NetApp Knowledge Base: The filesystem corruption on iSCSI LUN on the Oracle Linux 7.
1139053
Kernel disruption occurs on RHEL7.5 with QLogic QLE2672 16GB FC during storage failover operations
During storage failover operations on the RHEL7U5 kernel with QLogic QLE2672 16GB fibre channel host bus adapter, the kernel disruption occurs due to a panic in the kernel. The kernel panic causes RHEL 7.5 to reboot, which leads to an application disruption. The kernel panic generates the vmcore file under the /var/crash/directory if kdump is configured. The vmcore file is used to understand the cause of the failure. In this case, the panic was observed in the “get_next_timer_interrupt+440” module which is logged in the vmcore file with the following string: " [exception RIP: get_next_timer_interrupt+440]" After the kernel disruption, you can recover the operating system by rebooting the host operating system and restarting the application as required.
1138536
Kernel disruption occurs on RHEL7U5 with QLogic QLE2742 32GB FC during storage failover operations
During storage failover operations on the Red Hat Enterprise Linux (RHEL) RHEL7U5 kernel with QLogic QLE2742 HBA, kernel disruption occurs due to a panic in the kernel. The kernel panic leads to a reboot of the operating system, causing an application disruption. The kernel panic generates the vmcore file under the /var/crash/ directory if kdump is configured. When the kernel panics, you can use the vmcore file to investigate the reason for the failure. The following example shows a panic in the bget_next_timer_interrupt+440b module. The panic is logged in the vmcore file with the following string: " [exception RIP: get_next_timer_interrupt+440]" You can recover the operating system by rebooting the host OS and restarting the application as required.
1148090
Kernel disruption occurs on RHEL 7.5 with QLogic QLE2742 32GB FC HBA during storage failover operations
During storage failover operations on the Red Hat Enterprise Linux (RHEL) 7.5 kernel with a QLogic QLE2742 Fibre Channel (FC) host bus adapter (HBA), a kernel disruption occurs due to a panic in the kernel. The kernel panic causes RHEL 7.5 to reboot, which leads to an application disruption. If the kdump mechanism is enabled, the kernel panic generates a vmcore file located in the /var/crash/ directory. You can analyze the vmcore file to determine the cause of the panic. In this instance, when storage failover with the QLogic QLE2742 HBA event occurs, the "native_queued_spin_lock_slowpath+464" module is affected. You can locate the event in the vmcore file by finding the following string: " [exception RIP: native_queued_spin_lock_slowpath+464]" After the kernel disruption, you can reboot the Host OS and recover the operating system, and then you can restart the applications as required.
1146898
Kernel disruption occurs on RHEL 7.5 with Emulex HBAs during storage failover operations
During storage failover operations on a Red Hat Enterprise Linux (RHEL) 7.5 system with Emulex LPe32002-M2 32-GB FC host bus adapters (HBAs), a disruption in the kernel occurs. The kernel disruption causes a reboot of the operating system, which in turn causes an application disruption. If you configure kdump, the kernel disruption generates the vmcore file under the /var/crash/ directory. You can use the vmcore file to determine the cause of the failure. In the following example, you can see the disruption in the "lpfc_hba_clean_txcmplq+368" module. This disruption is logged in the vmcore file with the following string: " [exception RIP: lpfc_hba_clean_txcmplq+368]" After the kernel disruption, reboot the host OS to recover the operating system. Restart the application as required.
What's next?
  • Learn about using the Linux Host Utilities tool.
  • Learn about ASM mirroring.
    Automatic Storage Management (ASM) mirroring might require changes to the Linux multipath settings to allow ASM to recognize a problem and switch over to an alternate failure group. Most ASM configurations on ONTAP use external redundancy, which means that data protection is provided by the external array and ASM doesn't mirror data. Some sites use ASM with normal redundancy to provide two-way mirroring, normally across different sites. See Oracle databases on ONTAP for further information.
