Repair and remove the Windows Host Utilities for ONTAP storage
Use the Repair option in the Host Utilities installation program to update the Host bus adapter (HBA) and Windows registry settings. You can also remove the Host Utilities entirely, either interactively or from the Windows command line.
The Repair option updates the Windows registry and FC HBAs with the required settings. You can also remove the Host Utilities entirely.
Open Windows Programs and Features (Windows Server 2012 R2, Windows Server 2016, Windows Server 2019, and Windows 2022).
Select NetApp Windows Host Utilities.
Select Change.
Select Repair or Remove, as needed.
Follow the instructions on the screen.
The Repair option updates the Windows registry and FC HBAs with the required settings. You can also remove the Host Utilities entirely from a Windows command line.
Repair Windows Host Utilities:
msiexec /f installer.msi [/quiet]-
/frepairs the installation. -
installer.msiis the name of the Windows Host Utilities installation program on your system. -
/quietsuppresses all feedback and reboots the system automatically without prompting when the command completes.
