NVMe-oF Host Configuration for Oracle Linux 8.10 with ONTAP
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
You can use the following support and features with the NVMe-oF host configuration for Oracle Linux 8.10. You should also review the known limitations before starting the configuration process.
Support available:
Support for NVMe over TCP (NVMe/TCP) and NVMe over Fibre Channel (NVMe/FC). This gives the NetApp plug-in in the native nvme-cli package the capability to display the ONTAP information for both NVMe/FC and NVMe/TCP namespaces.
Depending on your host configuration, you configure NNMe/FC, NVMe/TCP, or both protocols.
Running NVMe and SCSI traffic simultaneously on the same host. For example, you can configure dm-multipath for SCSI
mpathdevices for SCSI LUNs and use NVMe multipath to configure NVMe-oF namespace devices on the host.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features available:
The in-kernel NVMe multipath feature is enabled for NVMe namespaces by default in Oracle Linux 8.10. You don't need to configure explicit settings.
Known limitations:
SAN booting using the NVMe-oF protocol is currently not supported.
NetApp sanlun host utility support isn't available for NVMe-oF on an Oracle Linux 8.10 host. Instead, you can rely on the NetApp plug-in included in the native
nvme-clipackage for all NVMe-oF transports.
Validate software versions
Validate the minimum supported software versions for Oracle Linux 8.10.
Install Oracle Linux 8.10 GA on the server. After the installation is complete, verify that you are running the specified Oracle Linux 8.10 GA kernel:
uname -r
5.15.0-206.153.7.1.el8uek.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cli
nvme-cli-1.16-9.el8.x86_64
On the Oracle Linux 8.10 host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqn
nqn.2014-08.org.nvmexpress:uuid:edd38060-00f7-47aa-a9dc-4d8ae0cd969a
Verify that
hostnqnon the Oracle Linux 8.10 host matcheshostnqnfor the corresponding subsystem on the ONTAP array:vserver nvme subsystem host show -vserver vs_coexistence_LPE36002
Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_coexistence_LPE36002 nvme regular nqn.2014-08.org.nvmexpress:uuid:edd38060-00f7-47aa-a9dc-4d8ae0cd969a nvme1 regular nqn.2014-08.org.nvmexpress:uuid:edd38060-00f7-47aa-a9dc-4d8ae0cd969a nvme2 regular nqn.2014-08.org.nvmexpress:uuid:edd38060-00f7-47aa-a9dc-4d8ae0cd969a nvme3 regular nqn.2014-08.org.nvmexpress:uuid:edd38060-00f7-47aa-a9dc-4d8ae0cd969a 4 entries were displayed.If the hostnqnstrings don't match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host. -
If you intend to run both NVMe and SCSI co-existent traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and
dm-multipathfor ONTAP LUNs respectively. This should exclude the ONTAP namespaces fromdm-multipathand preventdm-multipathfrom claiming the ONTAP namespace devices:-
Add the
enable_foreignsetting to the/etc/multipath.conffile:# cat /etc/multipath.conf defaults { enable_foreign NONE } -
Restart the
multipathddaemon to apply the new setting:systemctl restart multipathd
Configure NVMe/FC
You can configure NVMe/FC with Broadcom/Emulex FC or Marvell/Qlogic FC adapters. For NVMe/FC configured with a Broadcom adapter, you can enable I/O requests of size 1MB.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
cat /sys/class/scsi_host/host*/modelnameLPe36002-M64 LPe36002-M64
cat /sys/class/scsi_host/host*/modeldescEmulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
cat /sys/class/scsi_host/host*/fwrev14.4.317.10, sli-4:6:d 14.4.317.10, sli-4:6:d
cat /sys/module/lpfc/version0:14.2.0.13
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to "3":cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that the initiator ports are up and running and that you can see the target LIFs:
cat /sys/class/fc_host/host*/port_name0x100000109bf0449c 0x100000109bf0449d
cat /sys/class/fc_host/host*/port_stateOnline Online
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109bf0449c WWNN x200000109bf0449c DID x061500 ONLINE NVME RPORT WWPN x200bd039eab31e9c WWNN x2005d039eab31e9c DID x020e06 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2006d039eab31e9c WWNN x2005d039eab31e9c DID x020a0a TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000002c Cmpl 000000002c Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000000008ffe8 Issue 000000000008ffb9 OutIO ffffffffffffffd1 abort 0000000c noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000000c Err 0000000c NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109bf0449d WWNN x200000109bf0449d DID x062d00 ONLINE NVME RPORT WWPN x201fd039eab31e9c WWNN x2005d039eab31e9c DID x02090a TARGET DISCSRVC ONLINE NVME RPORT WWPN x200cd039eab31e9c WWNN x2005d039eab31e9c DID x020d06 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000041 Cmpl 0000000041 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000000936bf Issue 000000000009369a OutIO ffffffffffffffdb abort 00000016 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000016 Err 00000016
Configure NVMe/FC for a Marvell/QLogic adapter.
The native inbox qla2xxx driver included in the Oracle Linux 10 GA kernel has the latest fixes. These fixes are essential for ONTAP support. |
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameQLE2772 FW:v9.15.00 DVR:v10.02.09.100-k QLE2772 FW:v9.15.00 DVR:v10.02.09.100-k
Verify that
ql2xnvmeenableis set to "1". This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
Enable 1MB I/O size (Optional)
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w <host-traddr> -a <traddr>
Show example
# nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.24 Discovery Log Number of Records 20, Generation counter 45 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 6 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.6.25 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.5.24 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.6.24 sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.5.25 sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 6 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 traddr: 192.168.6.25 sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 ..........
Verify that all other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
Show example
# nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.24 # nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.25 # nvme discover -t tcp -w 192.168.5.1 -a 192.168.5.24 # nvme discover -t tcp -w 192.168.5.1 -a 192.168.5.25
Run the
nvme connect-allcommand across all supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w <host-traddr> -a <traddr> -l <ctrl_loss_timeout_in_seconds>
Show example
# nvme connect-all -t tcp -w 192.168.5.1 -a 192.168.5.24 -l -1 # nvme connect-all -t tcp -w 192.168.5.1 -a 192.168.5.25 -l -1 # nvme connect-all -t tcp -w 192.168.6.1 -a 192.168.6.24 -l -1 # nvme connect-all -t tcp -w 192.168.6.1 -a 192.168.6.25 -l -1
NetApp recommends setting the ctrl-loss-tmooption to "-1" so that the NVMe/TCP initiator attempts to reconnect indefinitely in the event of a path loss.
Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathY -
Verify that the NVMe-oF settings (such as model set to "NetApp ONTAP Controller" and load balancing iopolicy set to "round-robin") for the respective ONTAP namespaces correctly display on the host:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelNetApp ONTAP Controller NetApp ONTAP Controller
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyround-robin round-robin
Node SN Model --------------------------------------------------------- /dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n2 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n3 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF 2 85.90 GB / 85.90 GB 24 KiB + 0 B FFFFFFFF 3 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme0n1Show example
nvme-subsys0 - NQN=nqn.1992- 08.com.netapp: 4b4d82566aab11ef9ab8d039eab31e9d:subsystem.nvme\ +- nvme1 fc traddr=nn-0x2038d039eab31e9c:pn-0x203ad039eab31e9c host_traddr=nn-0x200034800d756a89:pn-0x210034800d756a89 live optimized +- nvme2 fc traddr=nn-0x2038d039eab31e9c:pn-0x203cd039eab31e9c host_traddr=nn-0x200034800d756a88:pn-0x210034800d756a88 live optimized +- nvme3 fc traddr=nn-0x2038d039eab31e9c:pn-0x203ed039eab31e9c host_traddr=nn-0x200034800d756a89:pn-0x210034800d756a89 live non-optimized +- nvme7 fc traddr=nn-0x2038d039eab31e9c:pn-0x2039d039eab31e9c host_traddr=nn-0x200034800d756a88:pn-0x210034800d756a88 live non-optimized
NVMe/TCPnvme list-subsys /dev/nvme0n1Show example
nvme-subsys0 - NQN=nqn.1992- 08.com.netapp: sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 \ +- nvme1 tcp traddr=192.168.5.25 trsvcid=4420 host_traddr=192.168.5.1 src_addr=192.168.5.1 live optimized +- nvme10 tcp traddr=192.168.6.24 trsvcid=4420 host_traddr=192.168.6.1 src_addr=192.168.6.1 live optimized +- nvme2 tcp traddr=192.168.5.24 trsvcid=4420 host_traddr=192.168.5.1 src_addr=192.168.5.1 live non-optimized +- nvme9 tcp traddr=192.168.6.25 trsvcid=4420 host_traddr=192.168.6.1 src_addr=192.168.6.1 live non-optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size -------------- ------------------------ ----------------------------- ---- ------------------------------------- --------- /dev/nvme0n1 vs_coexistence_QLE2772 /vol/fcnvme_1_1_0/fcnvme_ns 1 159f9f88-be00-4828-aef6-197d289d4bd9 10.74GB /dev/nvme0n2 vs_coexistence_QLE2772 /vol/fcnvme_1_1_1/fcnvme_ns 2 2c1ef769-10c0-497d-86d7-e84811ed2df6 10.74GB /dev/nvme0n3 vs_coexistence_QLE2772 /vol/fcnvme_1_1_2/fcnvme_ns 3 9b49bf1a-8a08-4fa8-baf0-6ec6332ad5a4 10.74GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_0/fcnvme_ns", "NSID" : 1, "UUID" : "159f9f88-be00-4828-aef6-197d289d4bd9", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 }, { "Device" : "/dev/nvme0n2", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_1/fcnvme_ns", "NSID" : 2, "UUID" : "2c1ef769-10c0-497d-86d7-e84811ed2df6", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 }, { "Device" : "/dev/nvme0n4", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_3/fcnvme_ns", "NSID" : 4, "UUID" : "f3572189-2968-41bc-972a-9ee442dfaed7", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 },
Known issues
The NVMe-oF host configuration for Oracle Linux 8.10 with ONTAP release has the following known issue:
| NetApp Bug ID | Title | Description |
CONTAPEXT-1082 |
Oracle Linux 8.10 NVMe-oF hosts create duplicate PDCs |
On Oracle Linux 8.10 NVMe-oF hosts, Persistent Discovery Controllers (PDCs) are created by using the |
