ONTAP SAN Host Utilities
NVMe-oF host configuration for RHEL 9.1 with ONTAP
Contributors netapp-ranuk netapp-pcarriga netapp-sarajane
NVMe over Fabrics or NVMe-oF (including NVMe/FC and NVMe/TCP) is supported with RHEL 9.1 with Asymmetric Namespace Access (ANA) that is required for surviving storage failovers (SFOs) on the ONTAP array. ANA is the asymmetric logical unit access (ALUA) equivalent in the NVMe-oF environment, and is currently implemented with in-kernel NVMe Multipath. Using this procedure, you can enable NVMe-oF with in-kernel NVMe Multipath using ANA on RHEL 9.1 and ONTAP as the target.
The following support is available for the NVMe-oF host configuration for RHEL 9.1 with ONTAP:
  • Support for NVMe over TCP (NVMe/TCP) in addition to NVMe/FC. The NetApp plug-in in the native nvme-cli package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
  • Use of NVMe and SCSI co-existent traffic on the same host on a given host bus adapter (HBA), without the explicit dm-multipath settings to prevent claiming NVMe namespaces.
Refer to the Interoperability Matrix Tool for accurate details regarding supported configurations.
Features
RHEL 9.1 includes support for in-kernel NVMe multipath for NVMe namespaces enabled by default, without the need for explicit settings.
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable in-kernel NVMe multipath
You can use the following procedure to enable in-kernel NVMe multipath.
Steps
  1. Install RHEL 9.1 on the server.
  2. After the installation is complete, verify that you are running the specified RHEL 9.1 kernel. See the Interoperability Matrix Tool for the current list of supported versions.
    Example:
    # uname -r
     5.14.0-162.6.1.el9_1.x86_64
  3. Install the nvme-cli package:
    Example:
    # rpm -qa|grep nvme-cli
    nvme-cli-2.0-4.el9.x86_64
  4. On the host, check the host NQN string at /etc/nvme/hostnqn and verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array. Example:
    # cat /etc/nvme/hostnqn
    nqn.2014-08.org.nvmexpress:uuid:325e7554-1f9b-11ec-8489-3a68dd61a4df
    ::> vserver nvme subsystem host show -vserver vs_nvme207
    Vserver     Subsystem       Host NQN
    vs_nvme207 rhel_207_LPe32002     nqn.2014-08.org.nvmexpress:uuid:325e7554-1f9b-11ec-8489-3a68dd61a4df
    Note If the host NQN strings do not match, you should use the vserver modify command to update the host NQN string on your corresponding ONTAP NVMe subsystem to match the host NQN string /etc/nvme/hostnqn on the host.
  5. Reboot the host.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Broadcom/Emulex
Steps
  1. Verify that you are using the supported adapter. See the Interoperability Matrix Tool for the current list of supported adapters.
    # cat /sys/class/scsi_host/host*/modelname
    LPe32002-M2
    LPe32002-M2
    # cat /sys/class/scsi_host/host*/modeldesc
    Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver. See the Interoperability Matrix Tool for the current list of supported adapter driver and firmware versions.
    # cat /sys/class/scsi_host/host*/fwrev
    14.0.505.11, sli-4:2:c
    # cat /sys/module/lpfc/version
    0:14.2.0.5
  3. Verify that lpfc_enable_fc4_type is set to 3
    # cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
    3
  4. Verify that the initiator ports are up and running, and that you can see the target LIFs.
    # cat /sys/class/fc_host/host*/port_name
    0x100000109b1b95ef
    0x100000109b1b95f0
    # cat /sys/class/fc_host/host*/port_state
    Online
    Online
    # cat /sys/class/scsi_host/host*/nvme_info
    NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x100000109b1b95ef WWNN x200000109b1b95ef DID x061700 ONLINE
    NVME RPORT       WWPN x2035d039ea1308e5 WWNN x2082d039ea1308e5 DID x062f05 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2083d039ea1308e5 WWNN x2082d039ea1308e5 DID x062407 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 000000000e Cmpl 000000000e Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 000000000001df6c Issue 000000000001df6e OutIO 0000000000000002
            abort 00000000 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000000 Err 00000004
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x100000109b1b95f0 WWNN x200000109b1b95f0 DID x061400 ONLINE
    NVME RPORT       WWPN x2036d039ea1308e5 WWNN x2082d039ea1308e5 DID x061605 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2037d039ea1308e5 WWNN x2082d039ea1308e5 DID x062007 TARGET DISCSRVC ONLINE
    NVME Statistics
    Total FCP Cmpl 000000000001dd28 Issue 000000000001dd29 OutIO 0000000000000001
Marvell/QLogic FC adapter for NVMe/FC
The native inbox qla2xxx driver included in the RHEL 9.1 kernel has the latest fixes which are. These fixes are essential for ONTAP support.
Steps
  1. Verify that you are running the supported adapter driver and firmware versions using the following command:
    # cat /sys/class/fc_host/host*/symbolic_name
    QLE2772 FW:v9.08.02 DVR:v10.02.07.400-k-debug
  2. Verify ql2xnvmeenable is set which enables the Marvell adapter to function as an NVMe/FC initiator using the following command:
    # cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    You should see an output similar to the following example:
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Steps
  1. Verify whether the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
    # nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51
    Discovery Log Number of Records 10, Generation counter 119
    =====Discovery Log Entry 0======
    trtype: tcp
    adrfam: ipv4
    subtype: nvme subsystem
    treq: not specified
    portid: 0
    trsvcid: 4420
    subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1
    traddr: 192.168.2.56
    sectype: none
    =====Discovery Log Entry 1======
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 1
    trsvcid: 4420
    traddr: 192.168.1.51
    sectype: none
    =====Discovery Log Entry 2======
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 0
    trsvcid: 4420
    subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_2
    sectype: none
  2. Verify that the other NVMe/TCP initiator-target LIF combos can successfully fetch discovery log page data. For example:
    # nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.52
    # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.56
    # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.57
  3. Run nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes. Make sure you set a longer ctrl_loss_tmo timer retry period (for example, 30 minutes, which can be set through -l 1800) while running the connect-all command so that it would retry for a longer period of time in the event of a path loss. For example:
    # nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.51 -l 1800
    # nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.52 -l 1800
    # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.56 -l 1800
    # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.57 -l 1800
Validate NVMe-oF
You can use the following procedure to validate NVMe-oF.
Steps
  1. Verify that in-kernel NVMe multipath is indeed enabled by checking:
    # cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces properly reflect on the host:
    # cat /sys/class/nvme-subsystem/nvme-subsys*/model
    # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
    round-robin
    round-robin
  3. Verify that the ONTAP namespaces properly reflect on the host. For example:
    # nvme list
    Node           SN                    Model                   Namespace
    /dev/nvme0n1   81CZ5BQuUNfGAAAAAAAB   NetApp ONTAP Controller   1
    Usage                Format         FW Rev
    85.90 GB / 85.90 GB  4 KiB + 0 B    FFFFFFFF
  4. Verify that the controller state of each path is live and has proper ANA status. For example:
    Example (a):
    # nvme list-subsys /dev/nvme0n1
    nvme-subsys10 - NQN=nqn.1992-08.com.netapp:sn.82e7f9edc72311ec8187d039ea14107d:subsystem.rhel_131_QLe2742
     +- nvme2 fc traddr=nn-0x2038d039ea1308e5:pn-0x2039d039ea1308e5,host_traddr=nn-0x20000024ff171d30:pn-0x21000024ff171d30 live non-optimized
     +- nvme3 fc traddr=nn-0x2038d039ea1308e5:pn-0x203cd039ea1308e5,host_traddr=nn-0x20000024ff171d31:pn-0x21000024ff171d31 live optimized
     +- nvme4 fc traddr=nn-0x2038d039ea1308e5:pn-0x203bd039ea1308e5,host_traddr=nn-0x20000024ff171d30:pn-0x21000024ff171d30 live optimized
     +- nvme5 fc traddr=nn-0x2038d039ea1308e5:pn-0x203ad039ea1308e5,host_traddr=nn-0x20000024ff171d31:pn-0x21000024ff171d31 live non-optimized
    Example (b):
    nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.bf0691a7c74411ec8187d039ea14107d:subsystem.rhel_tcp_133
     +- nvme1 tcp traddr=192.168.166.21,trsvcid=4420,host_traddr=192.168.166.5 live non-optimized
     +- nvme2 tcp traddr=192.168.166.20,trsvcid=4420,host_traddr=192.168.166.5 live optimized
     +- nvme3 tcp traddr=192.168.167.21,trsvcid=4420,host_traddr=192.168.167.5 live non-optimized
     +- nvme4 tcp traddr=192.168.167.20,trsvcid=4420,host_traddr=192.168.167.5 live optimized
  5. Verify that the NetApp plug-in displays proper values for each ONTAP namespace device.
    Example (a):
    # nvme netapp ontapdevices -o column
    Device       Vserver          Namespace Path
    /dev/nvme0n1 vs_tcp79     /vol/vol1/ns1
    NSID  UUID                                   Size
    1     79c2c569-b7fa-42d5-b870-d9d6d7e5fa84  21.47GB
    # nvme netapp ontapdevices -o json
      "ONTAPdevices" : [
          "Device" : "/dev/nvme0n1",
          "Vserver" : "vs_tcp79",
          "Namespace_Path" : "/vol/vol1/ns1",
          "NSID" : 1,
          "UUID" : "79c2c569-b7fa-42d5-b870-d9d6d7e5fa84",
          "Size" : "21.47GB",
          "LBA_Data_Size" : 4096,
          "Namespace_Size" : 5242880
    Example (b):
    /dev/nvme1n1     vs_tcp_133                /vol/vol1/ns1
    NSID UUID                                   Size
    1    1ef7cb56-bfed-43c1-97c1-ef22eeb92657   21.47GB
      "ONTAPdevices":[
          "Device":"/dev/nvme1n1",
          "Vserver":"vs_tcp_133",
          "Namespace_Path":"/vol/vol1/ns1",
          "NSID":1,
          "UUID":"1ef7cb56-bfed-43c1-97c1-ef22eeb92657",
          "Size":"21.47GB",
          "LBA_Data_Size":4096,
          "Namespace_Size":5242880
Known issues
The NVMe-oF host configuration for RHEL 9.1 with ONTAP has the following known issues:
NetApp Bug ID Title Description
1503468
nvme list-subsys command returns repeated nvme controller list for a given subsystem
The nvme list-subsys command should return a unique list of nvme controllers associated to a given subsystem. In RHEL 9.1, the nvme list-subsys command returns nvme controllers with its respective ANA state for all namespaces that belong to a given subsystem. However, the ANA state is a per-namespace attribute therefore, it would be ideal to display unique nvme controller entries with the path state if you list the subsystem command syntax for a given namespace.
