NVMe/FC Host Configuration for Oracle Linux 9.0 with ONTAP
NVMe over Fabrics (NVMe-oF), including NVMe/FC and other transports, is supported with Oracle Linux (OL) 9.0 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FC environments and is implemented with in-kernel NVMe multipath.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features
Oracle Linux 9.0 has in-kernel NVMe multipath enabled for NVMe namespaces by default, therefore, there is no need for explicit settings.
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Validate software versions
You can validate the minimum supported OL 9.0 software versions using the following procedure.
Install OL 9.0 GA on the server. After the installation is complete, verify that you are running the specified OL 9.0 GA kernel.
# uname -r
Example output:
5.15.0-0.30.19.el9uek.x86_64
Install the
nvme-clipackage:# rpm -qa|grep nvme-cli
Example output:
nvme-cli-1.16-3.el9.x86_64
On the Oracle Linux 9.0 host, check the
hostnqnstring at/etc/nvme/hostnqn:# cat /etc/nvme/hostnqn
Example output:
nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0032-3310-8033-b8c04f4c5132
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_ol_nvme
Example output:
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_ol_nvme nvme_ss_ol_1 nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0032-3310-8033-b8c04f4c5132
If the hostnqnstrings do not match, you can use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Verify that you are using the supported adapter model.
# cat /sys/class/scsi_host/host*/modelname
Example output:
LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc
Example output:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:# cat /sys/class/scsi_host/host*/fwrev 14.0.505.11, sli-4:2:c 14.0.505.11, sli-4:2:c # cat /sys/module/lpfc/version 0:12.8.0.11
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running, and that you can see the target LIFs:
# cat /sys/class/fc_host/host*/port_name 0x100000109b1c1204 0x100000109b1c1205 # cat /sys/class/fc_host/host*/port_state Online Online # cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
The native inbox qla2xxx driver included in the OL 9.0 GA kernel has the latest upstream fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k
Verify that
ql2xnvmeenableis set which enables the Marvell adapter to function as an NVMe/FC initiator:# cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Enable 1MB I/O size (Optional)
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddr
Example output:
# nvme discover -t tcp -w 192.168.6.13 -a 192.168.6.15 Discovery Log Number of Records 6, Generation counter 8 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.1c6ac66338e711eda41dd039ea3ad566:discovery traddr: 192.168.6.17 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.1c6ac66338e711eda41dd039ea3ad566:discovery traddr: 192.168.5.17 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.1c6ac66338e711eda41dd039ea3ad566:discovery traddr: 192.168.6.15 sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.1c6ac66338e711eda41dd039ea3ad566:subsystem.host_95 traddr: 192.168.6.17 sectype: none ..........
Verify that the other NVMe/TCP initiator-target LIF combinations are able to successfully fetch discovery log page data.
Example output:
# nvme discover -t tcp -w 192.168.5.13 -a 192.168.5.15 # nvme discover -t tcp -w 192.168.5.13 -a 192.168.5.17 # nvme discover -t tcp -w 192.168.6.13 -a 192.168.6.15 # nvme discover -t tcp -w 192.168.6.13 -a 192.168.6.17
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes, and set the controller loss timeout period for at least 30 minutes or 1800 seconds:nvme connect-all -t tcp -w host-traddr -a traddr -l 1800
Example output:
# nvme connect-all -t tcp -w 192.168.5.13 -a 192.168.5.15 -l 1800 # nvme connect-all -t tcp -w 192.168.5.13 -a 192.168.5.17 -l 1800 # nvme connect-all -t tcp -w 192.168.6.13 -a 192.168.6.15 -l 1800 # nvme connect-all -t tcp -w 192.168.6.13 -a 192.168.6.17 -l 1800
Validate NVMe-oF
You can use the following procedure to validate NVMe-oF.
Verify the following NVMe/FC settings on the OL 9.0 host:
# cat /sys/module/nvme_core/parameters/multipath Y # cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
# nvme list
Example output:
Node SN Model --------------------------------------------------------- /dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n2 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n3 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF 2 85.90 GB / 85.90 GB 24 KiB + 0 B FFFFFFFF 3 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
# nvme list-subsys /dev/nvme0n1
Example output:
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.5f5f2c4aa73b11e9967e00a098df41bd:subsystem.nvme_ss_ol_1 \ +- nvme0 fc traddr=nn-0x203700a098dfdd91:pn-0x203800a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme1 fc traddr=nn-0x203700a098dfdd91:pn-0x203900a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x203700a098dfdd91:pn-0x203a00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x203700a098dfdd91:pn-0x203d00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
# nvme netapp ontapdevices -o column
Example output:
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 vs_ol_nvme /vol/ol_nvme_vol_1_1_0/ol_nvme_ns /dev/nvme0n2 vs_ol_nvme /vol/ol_nvme_vol_1_0_0/ol_nvme_ns /dev/nvme0n3 vs_ol_nvme /vol/ol_nvme_vol_1_1_1/ol_nvme_ns NSID UUID Size ------------------------------------------------------------ 1 72b887b1-5fb6-47b8-be0b-33326e2542e2 85.90GB 2 04bf9f6e-9031-40ea-99c7-a1a61b2d7d08 85.90GB 3 264823b1-8e03-4155-80dd-e904237014a4 85.90GB
# nvme netapp ontapdevices -o json { "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_ol_nvme", "Namespace_Path" : "/vol/ol_nvme_vol_1_1_0/ol_nvme_ns", "NSID" : 1, "UUID" : "72b887b1-5fb6-47b8-be0b-33326e2542e2", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, { "Device" : "/dev/nvme0n2", "Vserver" : "vs_ol_nvme", "Namespace_Path" : "/vol/ol_nvme_vol_1_0_0/ol_nvme_ns", "NSID" : 2, "UUID" : "04bf9f6e-9031-40ea-99c7-a1a61b2d7d08", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, { "Device" : "/dev/nvme0n3", "Vserver" : "vs_ol_nvme", "Namespace_Path" : "/vol/ol_nvme_vol_1_1_1/ol_nvme_ns", "NSID" : 3, "UUID" : "264823b1-8e03-4155-80dd-e904237014a4", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, ] }
Known issues
The NVMe-oF host configuration for Oracle Linux 9.0 with ONTAP has the following known issues:
| NetApp Bug ID | Title | Description |
1517321 |
Oracle Linux 9.0 NVMe-oF Hosts create duplicate Persistent Discovery Controllers |
On Oracle Linux 9.0 NVMe over Fabrics (NVMe-oF) hosts, you can use the |
