NVMe/FC host configuration for RHEL 8.3 with ONTAP
Beginning with ONTAP 9.6, NVMe/FC is supported for Red Hat Enterprise Linux (RHEL) 8.3. The RHEL 8.3 host runs both NVMe and SCSI traffic through the same FC initiator adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers.
See the Interoperability Matrix Tool for the current list of supported configurations.
Features
There are no new features in this release.
Known limitations
For RHEL 8.3, in-kernel NVMe multipath is disabled by default. You can enable it manually.
SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Create a SAN boot namespace and map it to the host.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable NVMe/FC on RHEL 8.3
You can use the following procedure to enable NVMe/FC.
Install Red Hat Enterprise Linux 8.3 GA on the server.
If you are upgrading from RHEL 8.2 to RHEL 8.3 using the
yum update/upgrade
command, your/etc/nvme/host*
files might be lost. To avoid file loss, use the following procedure:Show example output
Backup your
/etc/nvme/host*
files. -
If you have a manually edited
udev
rule, remove it:/lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules
Perform the upgrade.
After the upgrade is complete, run the following command:
yum remove nvme-cli
Restore the host files at
/etc/nvme/
.yum install nvmecli
Copy the original
/etc/nvme/host*
contents from the backup to the actual host files at/etc/nvme/
After the installation is complete, verify that you're running the specified RHEL kernel:
# uname -r 4.18.0-240.el8.x86_64
See the Interoperability Matrix Tool for the current list of supported versions.
Install the nvme-cli package:
# rpm -qa|grep nvme-cli nvme-cli-1.12-2.el8.x86_64
Enable in-kernel NVMe multipath.
# grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-240.el8.x86_64
On the RHEL 8.3 host, check the host NQN string at
/etc/nvme/hostnqn
verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array:# cat /etc/nvme/hostnqn
Example output:
# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
Verify that the
hostnqn
string matches the hostnqn string for the corresponding subsystem on the ONTAP array:vserver nvme subsystem host show -vserver vs_fcnvme_141
Example output
::> vserver nvme subsystem host show -vserver vs_fcnvme_141 Vserver Subsystem Host NQN ----------- --------------- ----------- --------------- vs_fcnvme_141 nvme_141_1 nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
If the host NQN strings do not match, use the vserver modify
command to update the host NQN string on the corresponding ONTAP array subsystem to match to host NQN string from/etc/nvme/hostnqn
on the host. -
Reboot the host.
Optionally, update the
enable_foreign
setting.If you intend to run both NVMe and SCSI traffic on the same RHEL 8.3 host, NetApp recommends that you use in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs, respectively. You should also blacklist the ONTAP namespaces in dm-multipath to prevent dm-multipath from claiming these namespace devices. You can do this by adding the
enable_foreign
setting to the /etc/multipath.conf, as shown below:# cat /etc/multipath.conf defaults { enable_foreign NONE }
Restart the multipathd daemon by running a
systemctl restart multipathd
Validate NVMe/FC
You can use the following procedure to validate NVMe/FC.
Verify the following NVMe/FC settings:
# cat /sys/module/nvme_core/parameters/multipath Y
# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created and properly discovered on the host.
/dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF /dev/nvme0n2 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller 2 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF /dev/nvme0n3 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller 3 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify the status of the ANA paths.
# nvme list-subsys /dev/nvme0n1 nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.5f5f2c4aa73b11e9967e00a098df41bd:subsystem.nvme_141_1 \ +- nvme0 fc traddr=nn-0x203700a098dfdd91:pn-0x203800a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme1 fc traddr=nn-0x203700a098dfdd91:pn-0x203900a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x203700a098dfdd91:pn-0x203a00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x203700a098dfdd91:pn-0x203d00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized
Verify the NetApp plug-in for ONTAP devices:
Column# nvme netapp ontapdevices -o column
Example output
Device Vserver Namespace Path NSID UUID Size --------------- --------------- --------------------------------------------- -------- -------------------------------------- --------- /dev/nvme0n1 vs_fcnvme_141 /vol/fcnvme_141_vol_1_1_0/fcnvme_141_ns 1 72b887b1-5fb6-47b8-be0b-33326e2542e2 85.90GB /dev/nvme0n2 vs_fcnvme_141 /vol/fcnvme_141_vol_1_0_0/fcnvme_141_ns 2 04bf9f6e-9031-40ea-99c7-a1a61b2d7d08 85.90GB /dev/nvme0n3 vs_fcnvme_141 /vol/fcnvme_141_vol_1_1_1/fcnvme_141_ns 3 264823b1-8e03-4155-80dd-e904237014a4 85.90GB
JSON# nvme netapp ontapdevices -o json
Example output
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_fcnvme_141", "Namespace_Path" : "/vol/fcnvme_141_vol_1_1_0/fcnvme_141_ns", "NSID" : 1, "UUID" : "72b887b1-5fb6-47b8-be0b-33326e2542e2", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, { "Device" : "/dev/nvme0n2", "Vserver" : "vs_fcnvme_141", "Namespace_Path" : "/vol/fcnvme_141_vol_1_0_0/fcnvme_141_ns", "NSID" : 2, "UUID" : "04bf9f6e-9031-40ea-99c7-a1a61b2d7d08", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, { "Device" : "/dev/nvme0n3", "Vserver" : "vs_fcnvme_141", "Namespace_Path" : "/vol/fcnvme_141_vol_1_1_1/fcnvme_141_ns", "NSID" : 3, "UUID" : "264823b1-8e03-4155-80dd-e904237014a4", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, ]
Configure the Broadcom FC adapter for NVMe/FC
You can use the following procedure to configure a Broadcom FC adapter.
For the current list of supported adapters, see the Interoperability Matrix Tool.
Verify that you are using the supported adapter.
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that
lpfc_enable_fc4_type
is set to "3".# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running and can see the target LIFs.
# cat /sys/class/fc_host/host*/port_name 0x100000109b1c1204 0x100000109b1c1205
# cat /sys/class/fc_host/host*/port_state Online Online
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
Enable 1MB I/O size (optional).
The
lpfc_sg_seg_cnt
parameter needs to be set to 256 for the lpfc driver to issue I/O requests up to 1MB in size.# cat /etc/modprobe.d/lpfc.conf options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -f
command and then reboot the host. -
After the host boots up, verify that lpfc_sg_seg_cnt is set to 256.
# cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt 256
Verify that you are using the recommended Broadcom lpfc firmware as well as the inbox driver:
# cat /sys/class/scsi_host/host*/fwrev 12.8.340.8, sli-4:2:c 12.8.340.8, sli-4:2:c
# cat /sys/module/lpfc/version 0:12.8.0.1
