NVMe/FC Host Configuration for SUSE Linux Enterprise Server 15 SP2 with ONTAP
NVMe/FC is supported on ONTAP 9.6 and above with SUSE Linux Enterprise Server 15 SP2. The SUSE Linux Enterprise Server 15 SP2 host can run both NVMe/FC, and FCP traffic through the same fibre channel initiator adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers.
For the current list of supported configurations and versions, see the Interoperability Matrix Tool.
You can use the configuration settings provided in this procedure to configure cloud clients connected to Cloud Volumes ONTAP and Amazon FSx for ONTAP. |
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Enable NVMe/FC on SUSE Linux Enterprise Server 15 SP2
Upgrade to the recommended SUSE Linux Enterprise Server 15 SP2 MU kernel version.
Upgrade the native nvme-cli package.
This native nvme-cli package contains the NVMe/FC auto-connect scripts, ONTAP udev rule which enables round-robin load balancing for NVMe Multipath as well as the NetApp plug-in for ONTAP namespaces.
# rpm -qa|grep nvme-cli nvme-cli-1.10-2.38.x86_64
On the SUSE Linux Enterprise Server 15 SP2 host, check the host NQN string at
/etc/nvme/hostnqnand verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array. For example:# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:3ca559e1-5588-4fc4-b7d6-5ccfb0b9f054
::> vserver nvme subsystem host show -vserver vs_fcnvme_145 Vserver Subsystem Host NQN ------- --------- ---------------------------------------------------------- vs_fcnvme_145 nvme_145_1 nqn.2014-08.org.nvmexpress:uuid:c7b07b16-a22e-41a6-a1fd-cf8262c8713f nvme_145_2 nqn.2014-08.org.nvmexpress:uuid:c7b07b16-a22e-41a6-a1fd-cf8262c8713f nvme_145_3 nqn.2014-08.org.nvmexpress:uuid:c7b07b16-a22e-41a6-a1fd-cf8262c8713f nvme_145_4 nqn.2014-08.org.nvmexpress:uuid:c7b07b16-a22e-41a6-a1fd-cf8262c8713f nvme_145_5 nqn.2014-08.org.nvmexpress:uuid:c7b07b16-a22e-41a6-a1fd-cf8262c8713f 5 entries were displayed.
Reboot the host.
Configure the Broadcom FC Adapter for NVMe/FC
Verify that you are using the supported adapter. For the current list of supported adapters see the Interoperability Matrix Tool.
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom lpfc firmware and native inbox driver versions.
# cat /sys/class/scsi_host/host*/fwrev 12.6.240.40, sli-4:2:c 12.6.240.40, sli-4:2:c
# cat /sys/module/lpfc/version 0:12.8.0.2
Verify that lpfc_enable_fc4_type is set to 3.
# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running.
# cat /sys/class/fc_host/host*/port_name 0x100000109b579d5e 0x100000109b579d5f
# cat /sys/class/fc_host/host*/port_state Online Online
Verify that the NVMe/FC initiator ports are enabled, running and able to see the target LIFs.
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b579d5e WWNN x200000109b579d5e DID x011c00 ONLINE NVME RPORT WWPN x208400a098dfdd91 WWNN x208100a098dfdd91 DID x011503 TARGET DISCSRVC ONLINE NVME RPORT WWPN x208500a098dfdd91 WWNN x208100a098dfdd91 DID x010003 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000e49 Cmpl 0000000e49 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000003ceb594f Issue 000000003ce65dbe OutIO fffffffffffb046f abort 00000bd2 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000014f4 Err 00012abd NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b579d5f WWNN x200000109b579d5f DID x011b00 ONLINE NVME RPORT WWPN x208300a098dfdd91 WWNN x208100a098dfdd91 DID x010c03 TARGET DISCSRVC ONLINE NVME RPORT WWPN x208200a098dfdd91 WWNN x208100a098dfdd91 DID x012a03 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000e50 Cmpl 0000000e50 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000003c9859ca Issue 000000003c93515e OutIO fffffffffffaf794 abort 00000b73 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000159d Err 000135c3
Validate NVMe/FC
Verify the following NVMe/FC settings.
# cat /sys/module/nvme_core/parameters/multipath Y
# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin
Verify that the namespaces are created.
# nvme list Node SN Model Namespace Usage Format FW Rev ---------------- -------------------- ---------------------------------------- --------- -------------------------- ---------------- -------- /dev/nvme1n1 814vWBNRwfBGAAAAAAAB NetApp ONTAP Controller 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify the status of the ANA paths.
# nvme list-subsys /dev/nvme1n1 nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.04ba0732530911ea8e8300a098dfdd91:subsystem.nvme_145_1 \ +- nvme2 fc traddr=nn-0x208100a098dfdd91:pn-0x208200a098dfdd91 host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live inaccessible +- nvme3 fc traddr=nn-0x208100a098dfdd91:pn-0x208500a098dfdd91 host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live inaccessible +- nvme4 fc traddr=nn-0x208100a098dfdd91:pn-0x208400a098dfdd91 host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live optimized +- nvme6 fc traddr=nn-0x208100a098dfdd91:pn-0x208300a098dfdd91 host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live optimized
Verify the NetApp plug-in for ONTAP devices.
# nvme netapp ontapdevices -o column Device Vserver Namespace Path NSID UUID Size ---------------- ------------------------- -------------------------------------------------- ---- -------------------------------------- --------- /dev/nvme1n1 vserver_fcnvme_145 /vol/fcnvme_145_vol_1_0_0/fcnvme_145_ns 1 23766b68-e261-444e-b378-2e84dbe0e5e1 85.90GB # nvme netapp ontapdevices -o json { "ONTAPdevices" : [ { "Device" : "/dev/nvme1n1", "Vserver" : "vserver_fcnvme_145", "Namespace_Path" : "/vol/fcnvme_145_vol_1_0_0/fcnvme_145_ns", "NSID" : 1, "UUID" : "23766b68-e261-444e-b378-2e84dbe0e5e1", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 }, ] }
Known issues
There are no known issues.
Enable 1MB I/O Size for Broadcom NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
LPFC Verbose Logging
Set the lpfc driver for NVMe/FC.
Set the
lpfc_log_verbosedriver setting to any of the following values to log NVMe/FC events.#define LOG_NVME 0x00100000 /* NVME general events. */ #define LOG_NVME_DISC 0x00200000 /* NVME Discovery/Connect events. */ #define LOG_NVME_ABTS 0x00400000 /* NVME ABTS events. */ #define LOG_NVME_IOERR 0x00800000 /* NVME IO Error events. */
After setting the values, run the
dracut-fcommand and reboot the host. -
Verify the settings.
# cat /etc/modprobe.d/lpfc.conf options lpfc lpfc_log_verbose=0xf00083 # cat /sys/module/lpfc/parameters/lpfc_log_verbose 15728771
