NVMe/FC Host Configuration for Oracle Linux 8.6 with ONTAP
You can configure NVMe over Fibre Channel (NVMe/FC) on initiator hosts running Oracle Linux 8.6 and ONTAP as the target.
Supportability
NVMe over Fabrics or NVMe-oF (including NVMe/FC and NVMe/TCP) is supported with Oracle Linux 8.6 with Asymmetric Namespace Access (ANA) that is required for surviving storage failovers (SFOs) on the ONTAP array. ANA is the asymmetric logical unit access (ALUA) equivalent in the NVMe-oF environment, and is currently implemented with in-kernel NVMe Multipath. Using this procedure, you can enable NVMe-oF with in-kernel NVMe Multipath using ANA on Oracle Linux 8.6 and ONTAP as the target.
You can use the configuration settings provided in this procedure to configure cloud clients connected to Cloud Volumes ONTAP and Amazon FSx for ONTAP. |
Features
Oracle Linux 8.6 has in-kernel NVMe multipath enabled by default for NVMe namepsaces.
With Oracle Linux 8.6,
nvme-fc auto-connectscripts are included in the nativenvme-clipackage. You can use these native auto-connect scripts instead of installing external vendor provided outbox auto-connect scripts. -
With Oracle Linux 8.6, a native
udevrule is provided as part of thenvme-clipackage which enables round-robin load balancing for NVMe multipath. Therefore, you need not manually create this rule anymore. -
With Oracle Linux 8.6, both NVMe and SCSI traffic can be run on the same host. This is the commonly deployed host configuration. You can configure dm-multipath as usual for SCSI LUNs resulting in mpath devices and also use NVMe multipath to configure NVMe-oF multipath devices (for example,
/dev/nvmeXnY) on the host. -
With Oracle Linux 8.6, the NetApp plug-in in the native
nvme-clipackage is capable of displaying ONTAP details as well as ONTAP namespaces.
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Configuration requirements
Refer to the Interoperability Matrix Tool for exact details regarding supported configurations.
Enable NVMe/FC with Oracle Linux 8.6
Install Oracle Linux 8.6 GA on the server. After the installation is complete, verify that you are running the specified Oracle Linux 8.6 GA kernel. See the Interoperability Matrix Tool for the current list of supported versions.
# uname -r 5.4.17-2136.307.3.1.el8uek.x86_64
Install the
nvme-clipackage:# rpm -qa|grep nvme-cli nvme-cli-1.14-3.el8.x86_64
On the Oracle Linux 8.6 host, check the
hostnqnstring at/etc/nvme/hostnqnand verify that it matches the hostnqn string for the corresponding subsystem on the ONTAP array.# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0032-3310-8033-b8c04f4c5132 ::> vserver nvme subsystem host show -vserver vs_ol_nvme Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_ol_nvme nvme_ss_ol_1 nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
If the hostnqnstrings do not match, you should use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match to thehostnqnstring from/etc/nvme/hostnqnon the host: -
Reboot the host.
If you intend to run both NVMe and SCSI traffic on the same Oracle Linux 8.6 host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs respectively. This also means the ONTAP namespaces should be blacklisted in dm-multipath to prevent dm-multipath from claiming these namespace devices. This can be done by adding the
enable_foreignsetting to the/etc/multipath.conffile:#cat /etc/multipath.conf defaults { enable_foreign NONE }Restart the multipathd daemon by running the
systemctl restart multipathdcommand to let the new setting take effect.
Configure Broadcom FC adapter for NVMe/FC
Verify that you are using the supported adapter. For the current list of supported adapters see the Interoperability Matrix Tool:
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2 # cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver. For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool:# cat /sys/class/scsi_host/host*/fwrev 14.0.505.11, sli-4:2:c 14.0.505.11, sli-4:2:c # cat /sys/module/lpfc/version 0:12.8.0.11
Verify that
lpfc_enable_fc4_typeis set to3:# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running, and that you can see the target LIFs:
# cat /sys/class/fc_host/host*/port_name 0x100000109b1c1204 0x100000109b1c1205 # cat /sys/class/fc_host/host*/port_state Online Online # cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
Enable 1MB I/O size
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure the Marvell/QLogic FC Adapter for NVMe/FC
The native inbox qla2xxx driver included in the OL 8.6 GA kernel has the latest upstream fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k
Verify that
ql2xnvmeenableis set which enables the Marvell adapter to function as an NVMe/FC initiator:# cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
# nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51 Discovery Log Number of Records 10, Generation counter 119 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.2.56 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.1.51 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_2 traddr: 192.168.2.56 sectype: none ...
Similarly, verify that the other NVMe/TCP initiator-target LIF combinations are able to successfully fetch discovery log page data.
Example,#nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51 # nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.52 # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.56 # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.57
Now run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes. MAke sure you pass a longerctrl_loss_tmoperiod (such as, say 30 minutes, which can be set through-l 1800) during theconnect-allso that it would retry for a longer period in the event of a path loss. For example,# nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.51 -l 1800 # nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.52 -l 1800 # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.56 -l 1800 # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.57 -l 1800
Validate NVMe/FC
Verify the following NVMe/FC settings on the Oracle Linux 8.6 host:
# cat /sys/module/nvme_core/parameters/multipath Y # cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
# nvme list Node SN Model --------------------------------------------------------- /dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n2 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n3 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF 2 85.90 GB / 85.90 GB 24 KiB + 0 B FFFFFFFF 3 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
# nvme list-subsys /dev/nvme0n1 nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.5f5f2c4aa73b11e9967e00a098df41bd:subsystem.nvme_ss_ol_1 \ +- nvme0 fc traddr=nn-0x203700a098dfdd91:pn-0x203800a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme1 fc traddr=nn-0x203700a098dfdd91:pn-0x203900a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x203700a098dfdd91:pn-0x203a00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x203700a098dfdd91:pn-0x203d00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
# nvme netapp ontapdevices -o column Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 vs_ol_nvme /vol/ol_nvme_vol_1_1_0/ol_nvme_ns /dev/nvme0n2 vs_ol_nvme /vol/ol_nvme_vol_1_0_0/ol_nvme_ns /dev/nvme0n3 vs_ol_nvme /vol/ol_nvme_vol_1_1_1/ol_nvme_ns NSID UUID Size ------------------------------------------------------------ 1 72b887b1-5fb6-47b8-be0b-33326e2542e2 85.90GB 2 04bf9f6e-9031-40ea-99c7-a1a61b2d7d08 85.90GB 3 264823b1-8e03-4155-80dd-e904237014a4 85.90GB
# nvme netapp ontapdevices -o json
"ONTAPdevices" : [
"Device" : "/dev/nvme0n1",
"Vserver" : "vs_ol_nvme",
"Namespace_Path" : "/vol/ol_nvme_vol_1_1_0/ol_nvme_ns",
"NSID" : 1,
"UUID" : "72b887b1-5fb6-47b8-be0b-33326e2542e2",
"Size" : "85.90GB",
"LBA_Data_Size" : 4096,
"Namespace_Size" : 20971520
"Device" : "/dev/nvme0n2",
"Namespace_Path" : "/vol/ol_nvme_vol_1_0_0/ol_nvme_ns",
"NSID" : 2,
"UUID" : "04bf9f6e-9031-40ea-99c7-a1a61b2d7d08",
"Size" : "85.90GB",
"Device" : "/dev/nvme0n3",
"Namespace_Path" : "/vol/ol_nvme_vol_1_1_1/ol_nvme_ns",
"NSID" : 3,
"UUID" : "264823b1-8e03-4155-80dd-e904237014a4",
"Size" : "85.90GB",
Known issues
The NVMe-oF host configuration for OL 8.6 with ONTAP has the following known issues:
| NetApp Bug ID | Title | Description |
1517321 |
Oracle Linux 8.6 NVMe-oF Hosts create duplicate Persistent Discovery Controllers |
On Oracle Linux 8.6 NVMe over Fabrics (NVMe-oF) hosts, you can use the |
