ONTAP SAN Host Utilities
Install AIX Host Utilities 6.1 for ONTAP storage
Contributors netapp-ranuk netapp-pcarriga netapp-aoife netapp-sarajane netapp-camdenc
The AIX Host Utilities help you manage ONTAP storage attached to an AIX host. NetApp strongly recommends installing the AIX Host Utilities to improve ONTAP storage management and assist NetApp support in gathering information about your configuration.
AIX Host Utilities 6.1 support the following transport protocols and AIX environments:
  • FC, FCoE, and iSCSI
  • AIX Microsoft Multipath I/O (MPIO)
  • PowerVM
    For more information about PowerVM, see the IBM PowerVM Live Partition Mobility Red Book.
About this task
  • You need to install the AIX Host Utilities SAN Toolkit with AIX MPIO to manage ONTAP storage attached to an AIX host.
  • When you install AIX Host Utilities, they don't change any settings on your AIX host.
Before you begin
  • Use the Interoperability Matrix Tool to verify that your AIX OS, protocol, and ONTAP version support SAN booting.
  • Enable dynamic tracking for all FC and FCoE initiators by running the chdev -l <fscsi_device> -a dyntrk=ye command on the AIX host.
Steps
  1. Log in to your host.
    AIX
    On an AIX host, log in as root.
    PowerVM
    On a PowerVM host:
    1. Log in as padmin.
    2. Become a root user:
      oem_setup_env
  2. Go to the NetApp Support Site and download the compressed file containing the Host Utilities to a directory on your host.
  3. Go to the directory containing the download.
  4. Decompress the file and extract the SAN Toolkit software package.
    tar -xvf ntap_aix_host_utilities_6.1.tar.gz
    The following directory is created when you decompress the file: ntap_aix_host_utilities_6.1. This directory will have one of the following subdirectories: MPIO, NON_MPIO, or SAN_Tool_Kit.
  5. Install the AIX MPIO:
    installp -aXYd /var/tmp/ntap_aix_host_utilities_6.1/MPIO NetApp.MPIO_Host_Utilities_Kit
  6. Install the SAN Toolkit:
    installp -aXYd /var/tmp/ntap_aix_host_utilities_6.1/SAN_Tool_Kit NetApp.SAN_toolkit
  7. Reboot the host.
  8. Verify the installation:
    sanlun version
