NVMe-oF Host Configuration for Oracle Linux 9.4 with ONTAP
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
The following support and features are available with the NVMe-oF host configuration for Oracle Linux 9.4 with ONTAP storage. You should also review the known limitations before starting the configuration process.
Support available:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe over Fibre Channel (NVMe/FC). The NetApp plug-in in the native nvme-cli package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
Running both NVMe and SCSI traffic on the same host. For example, you can configure dm-multipath for SCSI mpath devices on SCSI LUNs and use NVMe multipath to configure NVMe-oF namespace devices on the host.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features available:
Beginning with ONTAP 9.12.1, support for secure in-band authentication is introduced for NVMe/TCP. You can use secure in-band authentication for NVMe/TCP with Oracle Linux 9.4
Support for in-kernel NVMe multipath enabled for NVMe namespaces by default, therefore, there is no need for explicit settings.
Known limitations:
SAN booting using the NVMe-oF protocol is currently not supported.
Validate software versions
You can use the following procedure to validate the minimum supported Oracle Linux 9.4 software versions.
Install Oracle Linux 9.4 GA on the server. After the installation is complete, verify that you are running the specified Oracle Linux 9.4 GA kernel.
uname -r
5.15.0-205.149.5.1.el9uek.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cli
nvme-cli-2.6-5.el9.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvme
libnvme-1.6-1.el9.x86_64
On the Oracle Linux 9.4 host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqn
nqn.2014-08.org.nvmexpress:uuid:9c5d23fe-21c5-472f-9aa4-dc68de0882e9
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:vserver nvme subsystem host show -vserver vs_coexistence_149
Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_coexistence_149 nvme regular nqn.2014-08.org.nvmexpress:uuid:9c5d23fe-21c5-472f-9aa4-dc68de0882e9 nvme_1 regular nqn.2014-08.org.nvmexpress:uuid:9c5d23fe-21c5-472f-9aa4-dc68de0882e9 nvme_2 regular nqn.2014-08.org.nvmexpress:uuid:9c5d23fe-21c5-472f-9aa4-dc68de0882e9 nvme_3 regular nqn.2014-08.org.nvmexpress:uuid:9c5d23fe-21c5-472f-9aa4-dc68de0882e9 4 entries were displayed.If the hostnqnstrings don't match, you can use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Configure NVMe/FC
You can configure NVMe/FC with Broadcom/Emulex FC or Marvell/Qlogic FC adapters. For NVMe/FC configured with a Broadcom adapter, you can enable I/O requests of size 1MB.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
cat /sys/class/scsi_host/host*/modelnameLPe32002-M2 LPe32002-M2
cat /sys/class/scsi_host/host*/modeldescEmulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
cat /sys/class/scsi_host/host*/fwrev14.4.317.7, sli-4:2:c 14.4.317.7, sli-4:2:c
cat /sys/module/lpfc/version0:14.2.0.13
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type3
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_name0x100000109b3c081f 0x100000109b3c0820
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateOnline Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b3c081f WWNN x200000109b3c081f DID x081600 ONLINE NVME RPORT WWPN x2020d039eab0dadc WWNN x201fd039eab0dadc DID x08010c TARGET DISCSRVC ONLINE NVME RPORT WWPN x2024d039eab0dadc WWNN x201fd039eab0dadc DID x08030c TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000027d8 Cmpl 00000027d8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000315454fa Issue 00000000314de6a4 OutIO fffffffffff991aa abort 00000be4 noxri 00000000 nondlp 00001903 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000c92 Err 0000bda4 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b3c0820 WWNN x200000109b3c0820 DID x081b00 ONLINE NVME RPORT WWPN x2027d039eab0dadc WWNN x201fd039eab0dadc DID x08020c TARGET DISCSRVC ONLINE NVME RPORT WWPN x2025d039eab0dadc WWNN x201fd039eab0dadc DID x08040c TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000026ac Cmpl 00000026ac Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000312a5478 Issue 00000000312465a2 OutIO fffffffffffa112a abort 00000b01 noxri 00000000 nondlp 00001ae4 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000b53 Err 0000ba63
Configure NVMe/FC for a Marvell/QLogic adapter.
The native inbox qla2xxx driver included in the Oracle Linux 9.4 GA kernel has the latest fixes. These fixes are essential for ONTAP support. |
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_name
QLE2872 FW:v9.15.00 DVR:v10.02.09.100-k QLE2872 FW:v9.15.00 DVR:v10.02.09.100-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
1
Enable 1MB I/O size (Optional)
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddr
Show example
nvme discover -t tcp -w 192.168.166.4 -a 192.168.166.56 Discovery Log Number of Records 10, Generation counter 15 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 13 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.cf84a53c81b111ef8446d039ea9ea481:discovery traddr: 192.168.165.56 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 9 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.cf84a53c81b111ef8446d039ea9ea481:discovery traddr: 192.168.166.56 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 13 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.cf84a53c81b111ef8446d039ea9ea481:subsystem.nvme_tcp_2 traddr: 192.168.165.56 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w 192.168.166.4 -a 192.168.166.56 nvme discover -t tcp -w 192.168.165.3 -a 192.168.165.56
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr
nvme connect-all -t tcp -w 192.168.166.4 -a 192.168.166.56 nvme connect-all -t tcp -w 192.168.165.3 -a 192.168.165.56
Beginning with Oracle Linux 9.4, the setting for the NVMe/TCP
ctrl_loss_tmo timeoutis automatically set to "off". As a result:-
There are no limits on the number of retries (indefinite retry).
You don't need to manually configure a specific
ctrl_loss_tmo timeoutduration when using thenvme connectornvme connect-allcommands (option -l ). -
The NVMe/TCP controllers don't experience timeouts in the event of a path failure and remain connected indefinitely.
Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify the following NVMe/FC settings on the Oracle Liniux 9.4 host:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelNetApp ONTAP Controller NetApp ONTAP Controller
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyround-robin round-robin
nvme list
Show example
Node SN Model --------------------------------------------------------- /dev/nvme0n1 81K2iBXAYSG6AAAAAAAB NetApp ONTAP Controller /dev/nvme0n2 81K2iBXAYSG6AAAAAAAB NetApp ONTAP Controller /dev/nvme0n3 81K2iBXAYSG6AAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 3.78GB/10.74GB 4 KiB + 0 B FFFFFFFF 2 3.78GB/10.74GB 4 KiB + 0 B FFFFFFFF 3 3.78GB/10.74GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme0n1
Show example
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.5f074d527b7011ef8446d039ea9ea481:subsystem.nvme hostnqn=nqn.2014-08.org.nvmexpress:uuid:060fd513-83be-4c3e-aba1-52e169056dcf iopolicy=round-robin \ +- nvme10 fc traddr=nn-0x201fd039eab0dadc:pn-0x2024d039eab0dadc,host_traddr=nn-0x200000109b3c081f:pn-0x100000109b3c081f live non-optimized +- nvme15 fc traddr=nn-0x201fd039eab0dadc:pn-0x2020d039eab0dadc,host_traddr=nn-0x200000109b3c081f:pn-0x100000109b3c081f live optimized +- nvme7 fc traddr=nn-0x201fd039eab0dadc:pn-0x2025d039eab0dadc,host_traddr=nn-0x200000109b3c0820:pn-0x100000109b3c0820 live non-optimized +- nvme9 fc traddr=nn-0x201fd039eab0dadc:pn-0x2027d039eab0dadc,host_traddr=nn-0x200000109b3c0820:pn-0x100000109b3c0820 live optimizedNVMe/TCPnvme list-subsys /dev/nvme1n22
Show example
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.cf84a53c81b111ef8446d039ea9ea481:subsystem.nvme_tcp_1 hostnqn=nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57 iopolicy=round-robin \ +- nvme2 tcp traddr=192.168.166.56,trsvcid=4420,host_traddr=192.168.166.4,src_addr=192.168.166.4 live optimized +- nvme4 tcp traddr=192.168.165.56,trsvcid=4420,host_traddr=192.168.165.3,src_addr=192.168.165.3 live non-optimized -
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o column
Show example
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 vs_coexistence_147 /vol/fcnvme_1_1_0/fcnvme_ns /dev/nvme0n2 vs_coexistence_147 /vol/fcnvme_1_1_1/fcnvme_ns /dev/nvme0n3 vs_coexistence_147 /vol/fcnvme_1_1_2/fcnvme_ns NSID UUID Size ------------------------------------------------------------ 1 e605babf-1b54-417d-843b-bc14355b70c5 10.74GB 2 b8dbecc7-14c5-4d84-b948-73c7abf5af43 10.74GB 3 ba24d1a3-1911-4351-83a9-1c843d04633c 10.74GB
JSONnvme netapp ontapdevices -o json
Show example
{ "ONTAPdevices":[ { "Device":"/dev/nvme0n1", "Vserver":"vs_coexistence_147", "Namespace_Path":"/vol/fcnvme_1_1_0/fcnvme_ns", "NSID":1, "UUID":"e605babf-1b54-417d-843b-bc14355b70c5", "Size":"10.74GB", "LBA_Data_Size":4096, "Namespace_Size":2621440 }, { "Device":"/dev/nvme0n2", "Vserver":"vs_coexistence_147", "Namespace_Path":"/vol/fcnvme_1_1_1/fcnvme_ns", "NSID":2, "UUID":"b8dbecc7-14c5-4d84-b948-73c7abf5af43", "Size":"10.74GB", "LBA_Data_Size":4096, "Namespace_Size":2621440 }, { "Device":"/dev/nvme0n3", "Vserver":"vs_coexistence_147", "Namespace_Path":"/vol/fcnvme_1_1_2/fcnvme_ns", "NSID":3, "UUID":"c236905d-a335-47c4-a4b1-89ae30de45ae", "Size":"10.74GB", "LBA_Data_Size":4096, "Namespace_Size":2621440 }, ] }
Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP between an Oracle Linux 9.4 host and an ONTAP controller.
To set up secure authentication, each host or controller must be associated with a DH-HMAC-CHAP key, which is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
You can set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
Generate the dhchap key for the OL 9.4 host.
The following output describes the
gen-dhchap-keycommand paramters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
# nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57 DHHC-1:03:zSq3+upTmknih8+6Ro0yw6KBQNAXjHFrOxQJaE5i916YdM/xsUSTdLkHw2MMmdFuGEslj6+LhNdf5HF0qfroFPgoQpU=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secret
Show example output for a unidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme*/dhchap_secret DHHC-1:01:OKIc4l+fs+fmpAj0hMK7ay8tTIzjccUWSCak/G2XjgJpKZeK: DHHC-1:01:OKIc4l+fs+fmpAj0hMK7ay8tTIzjccUWSCak/G2XjgJpKZeK:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secret
Show example output for a bidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme*/dhchap_ctrl_secret DHHC-1:03:zSq3+upTmknih8+6Ro0yw6KBQNAXjHFrOxQJaE5i916YdM/xsUSTdLkHw2MMmdFuGEslj6+LhNdf5HF0qfroFPgoQpU=: DHHC-1:03:zSq3+upTmknih8+6Ro0yw6KBQNAXjHFrOxQJaE5i916YdM/xsUSTdLkHw2MMmdFuGEslj6+LhNdf5HF0qfroFPgoQpU=:
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
To generate the JSON file, you can use the -o option. See the NVMe connect-all manual pages for more syntax options.
Configure the JSON file:
Show example
cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57", "hostid":"9796c1ec-0d34-11eb-b6b2-3a68dd3bab57", "dhchap_key":"DHHC-1:01:OKIc4l+fs+fmpAj0hMK7ay8tTIzjccUWSCak\/G2XjgJpKZeK:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.cf84a53c81b111ef8446d039ea9ea481:subsystem.nvme_tcp_1", "ports":[ { "transport":"tcp", "traddr":"192.168.165.56", "host_traddr":"192.168.165.3", "trsvcid":"4420", "dhchap_key":"DHHC-1:01:OKIc4l+fs+fmpAj0hMK7ay8tTIzjccUWSCak\/G2XjgJpKZeK:", "dhchap_ctrl_key":"DHHC-1:03:zSq3+upTmknih8+6Ro0yw6KBQNAXjHFrOxQJaE5i916YdM\/xsUSTdLkHw2MMmdFuGEslj6+LhNdf5HF0qfroFPgoQpU=:" }, { "transport":"tcp", "traddr":"192.168.166.56", "host_traddr":"192.168.166.4", "trsvcid":"4420", "dhchap_key":"DHHC-1:01:OKIc4l+fs+fmpAj0hMK7ay8tTIzjccUWSCak\/G2XjgJpKZeK:", "dhchap_ctrl_key":"DHHC-1:03:zSq3+upTmknih8+6Ro0yw6KBQNAXjHFrOxQJaE5i916YdM\/xsUSTdLkHw2MMmdFuGEslj6+LhNdf5HF0qfroFPgoQpU=:" } ] } ] } ]In the preceding example, dhchap_keycorresponds todhchap_secretanddhchap_ctrl_keycorresponds todhchap_ctrl_secret. -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.json
Show example
traddr=192.168.165.56 is already connected traddr=192.168.165.56 is already connected traddr=192.168.165.56 is already connected traddr=192.168.165.56 is already connected traddr=192.168.165.56 is already connected traddr=192.168.165.56 is already connected traddr=192.168.166.56 is already connected traddr=192.168.166.56 is already connected traddr=192.168.166.56 is already connected traddr=192.168.166.56 is already connected traddr=192.168.166.56 is already connected traddr=192.168.166.56 is already connected
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secret
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secret
Known issues
There are no known issues for the Oracle Linux 9.4 with ONTAP release.
