NVMe-oF host configuration for RHEL 8.5 with ONTAP
NVMe over Fabrics or NVMe-oF (including NVMe/FC and other transports) is supported with Red Hat Enterprise Linux (RHEL) 8.5 with ANA (Asymmetric Namespace Access). ANA is the asymmetric logical unit access (ALUA) equivalent in the NVMe-oF environment, and is currently implemented with in-kernel NVMe Multipath. During this procedure, you enable NVMe-oF with in-kernel NVMe Multipath using ANA on RHEL 8.5 and ONTAP as the target.
See the Interoperability Matrix Tool for accurate details regarding supported configurations.
Features
RHEL 8.5 includes support for NVMe/TCP (as a Technology Preview feature) in addition to NVMe/FC. The NetApp plugin in the native nvme-cli package can display ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
Known limitations
For RHEL 8.5, in-kernel NVMe multipath remains disabled by default. Therefore, you need to enable it manually.
NVMe/TCP on RHEL 8.5 remains a Technology Preview feature due to open issues. Refer to the RHEL 8.5 Release Notes for details.
SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Create a SAN boot namespace and map it to the host.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable in-kernel NVMe Multipath
You can use the following procedure to enable in-kernel NVMe multipath.
Install RHEL 8.5 GA on the server. After the installation is complete, verify that you are running the specified RHEL 8.5 GA kernel. See the Interoperability Matrix Tool for the current list of supported versions.
Example:
# uname -r 4.18.0-348.el8.x86_64
Install the
nvme-cli
package:Example:
# rpm -qa|grep nvme-cli nvme-cli-1.14-3.el8.x86_64
Enable in-kernel NVMe multipath:
# grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-348.el8.x86_64
On the host, check the host NQN string at
/etc/nvme/hostnqn
and verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array. Example:# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1 ::> vserver nvme subsystem host show -vserver vs_fcnvme_141 Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_fcnvme_14 nvme_141_1 nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
If the host NQN strings do not match, you should use the vserver modify
command to update the host NQN string on your corresponding ONTAP NVMe subsystem to match the host NQN string/etc/nvme/hostnqn
on the host. -
Reboot the host.
If you intend to run both NVMe and SCSI co-existent traffic on the same host, NetApp recommends using in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs respectively. This means that the ONTAP namespaces should be excluded from dm-multipath to prevent dm-multipath from claiming these namespace devices. You can do this by adding the enable_foreign setting to the
/etc/multipath.conf
file:# cat /etc/multipath.conf defaults { enable_foreign NONE }
Restart the multipathd daemon by running a
systemctl restart multipathd
command to allow the new setting to take effect.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Verify that you are using the supported adapter. See the Interoperability Matrix Tool for the current list of supported adapters.
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2 # cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom lpfc firmware and inbox driver. See the Interoperability Matrix Tool for the current list of supported adapter driver and firmware versions.
# cat /sys/class/scsi_host/host*/fwrev 12.8.351.47, sli-4:2:c 12.8.351.47, sli-4:2:c # cat /sys/module/lpfc/version 0:12.8.0.10
Verify that
lpfc_enable_fc4_type
is set to 3# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running, and that you can see the target LIFs.
# cat /sys/class/fc_host/host*/port_name 0x100000109b1c1204 0x100000109b1c1205 # cat /sys/class/fc_host/host*/port_state Online Online # cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
The native inbox qla2xxx
driver included in the RHEL 8.5 GA kernel has the latest fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name QLE2742 FW:v9.06.02 DVR:v10.02.00.106-k QLE2742 FW:v9.06.02 DVR:v10.02.00.106-k
Verify
ql2xnvmeenable
is set which enables the Marvell adapter to function as a NVMe/FC initiator:# cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc
value of the lpfc_sg_seg_cnt
parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cnt
parameter to 256:cat /etc/modprobe.d/lpfc.conf
You should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -f
command, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cnt
is 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Verify whether the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
# nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51 Discovery Log Number of Records 10, Generation counter 119 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.2.56 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.1.51 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_2 traddr: 192.168.2.56 sectype: none ...
Verify that other NVMe/TCP initiator-target LIF combos can successfully fetch discovery log page data. For example:
# nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51 # nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.52 # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.56 # nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.57
Run the
nvme connect-all
command across all the supported NVMe/TCP initiator-target LIFs across the nodes. Ensure you set a longerctrl_loss_tmo
timer retry period (for example, 30 minutes, which can be set through-l 1800
) during the connect-all so that it retries for a longer period of time in the event of a path loss. For example:# nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.51 -l 1800 # nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.52 -l 1800 # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.56 -l 1800 # nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.57 -l 1800
Validate NVMe-oF
You can use the following procedure to validate NVMe-oF.
Verify that in-kernel NVMe multipath is enabled:
# cat /sys/module/nvme_core/parameters/multipath Y
Verify that the appropriate NVMe-oF settings (such as,
model
set toNetApp ONTAP Controller
andload balancing iopolicy
set toround-robin
) for the respective ONTAP namespaces properly reflect on the host:# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the ONTAP namespaces properly reflect on the host. For example:
# nvme list Node SN Model Namespace ------------ --------------------- --------------------------------- /dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller 1 Usage Format FW Rev ------------------- ----------- -------- 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has proper ANA status. For example:
# nvme list-subsys /dev/nvme0n1 nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.5f5f2c4aa73b11e9967e00a098df41bd:subsystem.nvme_141_1 \ +- nvme0 fc traddr=nn-0x203700a098dfdd91:pn-0x203800a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme1 fc traddr=nn-0x203700a098dfdd91:pn-0x203900a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x203700a098dfdd91:pn-0x203a00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x203700a098dfdd91:pn-0x203d00a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized
Verify that the NetApp plug-in displays proper values for each ONTAP namespace device. For example:
# nvme netapp ontapdevices -o column Device Vserver Namespace Path --------- ------- -------------------------------------------------- /dev/nvme0n1 vs_fcnvme_141 vol/fcnvme_141_vol_1_1_0/fcnvme_141_ns NSID UUID Size ---- ------------------------------ ------ 1 72b887b1-5fb6-47b8-be0b-33326e2542e2 85.90GB # nvme netapp ontapdevices -o json { "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_fcnvme_141", "Namespace_Path" : "/vol/fcnvme_141_vol_1_1_0/fcnvme_141_ns", "NSID" : 1, "UUID" : "72b887b1-5fb6-47b8-be0b-33326e2542e2", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 } ] }
Known issues
There are no known issues.
