The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Using BR*Tools with SnapManager for SAP
PDF of this doc site
Administration for UNIX
Installation and Administration for Windows
Creating your file...
Your file is ready
You can use SAP BR*Tools commands with SnapManager for SAP. BR*Tools is a SAP program package that contains SAP tools for Oracle database administration, for example, BRARCHIVE, BRBACKUP, BRCONNECT, BRRECOVER, BRRESTORE, BRSPACE, and BRTOOLS.
You can complete the following tasks related to using BR*Tools and SnapManager for SAP:
Disable client access to Snapshot copies
Specify the profile for BR*Tools backups
Create database backups using BRBACKUP and BRARCHIVE
Schedule backups with SAP transaction DB13
Restore a database using BRRESTORE and BRRECOVER
Back up and restore files using BR*Tools
Restore a backup to a different host
