SnapManager for SAP
Upgrade the SnapManager hosts
You can upgrade all of the existing hosts to use the latest version of SnapManager. All of the hosts are upgraded simultaneously. However, this might result in downtime of all the SnapManager hosts and the scheduled operations during that time.
Steps
  1. Log in to the host system as the root user.
  2. From the command-line interface (CLI), navigate to the location where you have downloaded the installation file.
  3. If the file is not executable, change the permissions: chmod 544 netapp.smsap*
  4. Stop the SnapManager server:
    smsap_server stop
  5. Depending on the UNIX host, install SnapManager:
    If the operating system is…​ Then run…​
    Solaris (SPARC64)
    # ./netapp.smsap.sunos-sparc64-version_number.bin
    Solaris (x86_64)
    # ./netapp.smsap.sunos-x64-version_number.bin
    AIX (PPC64)
    # ./netapp.smsap.aix-ppc64-version_number.bin
    Linux x86
    # ./netapp.smsap.linux-x86-version_number.bin
    Linux x64
    # ./netapp.smsap.linux-x64-version_number.bin
  6. On the Introduction page, press Enter to continue.
    The following message is displayed: Existing SnapManager For SAP Detected.
  7. Press Enter.
  8. At the command prompt, perform the following:
    1. Change the default value of the operating system user to ora sid.
      sid is the system identifier of the SAP database.
    2. Enter the correct value for the operating system group or press Enter to accept the default value.
    3. Enter the correct value for the server startup type or press Enter to accept the default value.
    The configuration summary is displayed.
  9. Press Enter to continue.
    The following message is displayed: Uninstall of Existing SnapManager For SAP has started.
    The uninstallation is completed and the latest version of SnapManager is installed.
