SnapManager for SAP
View the status of the clone split process
You can view the progress of the split process you started.
Step
  1. To view the progress of the clone split process, enter the following command:
    smsap clone split-status -profile profile [-host hostname] [-label split-label | -id split-id] [-quiet | -verbose]
smsap clone split-status -profile p1 -id 8abc01ec0e78f3e2010e78f3fdd00001
