The smsap clone split command
You can run the clone split command to split a clone. The split clone becomes independent of the original clone. SnapManager generates a new profile after the clone split operation and you can use this profile to manage the split clone.
Syntax
smsap clone split
-profile clone-profile
[-host hostname]
{-label clone-label | -id clone-id} [-split-label split-operation_label]
[-comment comment]
-new-profile new-profile-name [-profile-password new-profile_password]
-repository -dbname repo_service_name
-host repo_host
-port repo_port
-login -username repo_username
-database -dbname db_dbname
-host db_host [-sid db_sid] [-login -username db_username -password db_password
-port db_port]
[-rman {{-controlfile | {-login -username rman_username
-password rman_password} -tnsname rman_tnsname}}]
-osaccount osaccount
-osgroup osgroup
[-retain
[-hourly [-count n] [-duration m]]
[-daily [-count n] [-duration m]]
[-weekly [-count n] [-duration m]]
[-monthly [-count n] [-duration m]] ]
[-profile-comment profile-comment]
[-snapname-pattern pattern]
[-protect [-protection-policy policy_name]] | [-noprotect]]
[-summary-notification
[-notification
[-success -email email_address1,email_address2
-subject subject-pattern]
[failure -email email_address1,email_address2
-subject subject-pattern] ]
[-separate-archivelog-backups
-retain-archivelog-backups -hours hours |
-days days |
-weeks weeks |
-months months
[-protect [-protection-policy policy_name | -noprotect]
[-include-with-online-backups | -no-include-with-online-backups]]
[-dump]
[-quiet | -verbose]
-profile clone-profileSpecifies the profile name from which the clone is created.
-host hostnameSpecifies the host name in which the clone exists.
label clone-labelSpecifies the label name generated by the clone operation.
-id clone-idSpecifies the unique ID generated by the clone operation.
-split-label split-operation_labelSpecifies the label name generated by the clone operation.
-new-profile new-profile_nameSpecifies the new profile name that SnapManager will generate after a successful split operation.
-profile-password new-profile_passwordSpecifies the password for the profile.
-repositorySpecifies the details of the database for the repository.
-dbname repo_service_nameSpecifies the name of the database that stores the repository. You can use either the global name or system identifier.
-host repo_hostSpecifies the name or IP address of the host computer on which the repository database resides.
-port repo_portSpecifies the Transmission Control Protocol (TCP) port number used to access the host on which the repository database resides.
-loginSpecifies the repository login details. This is optional. If not specified, SnapManager defaults to OS Authentication Connection Mode.
-username repo_usernameSpecifies the user name required to access the host on which the repository database resides.
-databaseSpecifies the details of the database that will be backed up, restored, or cloned.
-dbname db_dbnameSpecifies the name of the database that the profile describes. You can use either the global name or system identifier.
-host db_hostSpecifies the name or IP address of the host computer on which the database resides.
-sid db_sidSpecifies the system identifier of the database that the profile describes. By default, SnapManager uses the database name as the system identifier. If the system identifier is different from the database name, you must specify it using the
-sidoption. -
-loginSpecifies the database login details.
-username db_usernameSpecifies the user name needed to access the database that the profile describes.
-password db_passwordSpecifies the password needed to access the database that the profile describes.
-osaccount osaccountSpecifies the name of the Oracle database user account. SnapManager uses this account to perform the Oracle operations such as startup and shutdown. It is typically the user who owns the Oracle software on the host, for example, orasid.
-osgroup osgroupSpecifies the name of the Oracle database group name associated with the orasid account.
The -osaccountand-osgroupvariables are required for UNIX but not allowed for databases running on Windows. -
-retain [-hourly [-count n] [-duration m]] [-daily [-count n] [-duration m]] [-weekly [-count n] [-duration m]] [-monthly [-count n] [-duration m]]Specifies the retention policy for a backup.
For each retention class, either or both the retention count or retention duration might be specified. The duration is in units of the class (for example, hours for hourly, days for daily). For instance, if you specify only a retention duration of 7 for daily backups, then SnapManager will not limit the number of daily backups for the profile (because the retention count is 0), but SnapManager will automatically delete daily backups created over 7 days ago.
-profile-comment profile-commentSpecifies the comment for a profile describing the profile domain.
-snapname-pattern patternSpecifies the naming pattern for Snapshot copies. You can also include custom text, for example, HAOPS for highly available operations, in all Snapshot copy names. You can change the Snapshot copy naming pattern when you create a profile or after the profile has been created. The updated pattern applies only to Snapshot copies that have not yet been created. Snapshot copies that exist retain the previous Snapname pattern. You can use several variables in the pattern text.
-protect -protection-policy policy_nameSpecifies whether the backup should be protected to secondary storage.
If -protectis specified without-protection-policy, then the dataset will not have a protection policy. If-protectis specified and-protection-policyis not set when the profile is created, then it may be set later by thesmsap profile updatecommand or set by the storage administrator by using the Protection Manager's console. -
-summary-notificationSpecifies the details for configuring summary email notification for multiple profiles under a repository database. SnapManager generates this email.
-notificationSpecifies the details for configuring email notification for the new profile. SnapManager generates this email. The email notification enables the database administrator to receive emails on the succeeded or failed status of the database operation that is performed by using this profile.
-successSpecifies that email notification is enabled for a profile for when the SnapManager operation succeeds.
-email email address 1 email address 2Specifies the email address of the recipient.
-subject subject-patternSpecifies the email subject.
-failureSpecifies that email notification is enabled for a profile for when the SnapManager operation fails.
-separate-archivelog-backupsSpecifies that the archive log backup is separated from the datafile backup. This is an optional parameter, which you can provide while creating the profile. After the backups are separated by using this option, you can either create datafiles-only backup or archive logs-only backup.
-retain-archivelog-backups -hours hours | -days days | -weeks weeks| -months monthsSpecifies that the archive log backups are retained based on the archive log retention duration (hourly, daily, weekly, or monthly).
protect [-protection-policy policy_name] | -noprotectSpecifies that the archive log files is protected based on the archive log protection policy.
Specifies that the archive log files are not protected by using the
-noprotectoption. -
-include-with-online-backups | -no-include-with-online-backupsSpecifies that the archive log backup is included along with the online database backup.
Specifies that the archive log backups are not included along with the online database backup.
-dumpSpecifies that the dump files are not collected after the successful profile create operation.
-quietDisplays only error messages in the console. The default setting displays error and warning messages.
-verboseDisplays error, warning, and informational messages in the console.
