Configure SnapManager to support the Veritas SFRAC environment
When SnapManager is installed on Solaris, you can configure SnapManager to support the Veritas Storage Foundation for Oracle RAC (SFRAC) environment.
What you'll need
The host must have Solaris, host utilities, and Veritas installed.
Steps
Create a shared disk group and a file system for SnapManager by using SnapDrive for UNIX so that the file systems are concurrently mounted on both nodes of the Real Application Clusters (RAC).
For information about how to create a shared disk group and file system, see SnapDrive documentation.
Install and configure the SAP database that is to be mounted on the shared file systems.
Start a database instance on any one node of the RAC.
