SnapManager for SAP
Configure SnapDrive when RBAC is not enabled
You must register the root user or the administrator of the DataFabric Manager server and root user of the storage system with SnapDrive to enable data protection.
Steps
  1. To refresh the DataFabric Manager server to update the changes made directly on the storage system by the target database, enter the following command:
    Example
    dfm host discover storage_system
  2. To register the root user or the administrator of the DataFabric Manager server with SnapDrive, enter the following command:
    Example
    snapdrive config set -dfm Administratordfm_host
  3. To Register the root user or the administrator of the storage system with SnapDrive, enter the following command:
    Example
    snapdrive config set root storage_system
