SnapManager for SAP
The smsap backup mount command
You can run the backup mount command to mount a backup in order to perform a recover operation by using an external tool.
Syntax
smsap backup mount
-profile profile_name
[-label label [-data | -archivelogs] | [-id id]
[-host  host
[-from-secondary {-copy-id _id_}]
[-dump]
[-quiet | -verbose]]
  • -profile profile_name
    Specifies the profile associated with the backup that you want to mount. The profile contains the identifier of the database and other database information.
  • -id guid
    Mounts the backup with the specified GUID. The GUID is generated by SnapManager when you create a backup. You can use the smsap backup list command to display the GUID for each backup.
  • -label label
    Mounts the backup with the specified label.
  • -data
    Specifies the data files.
  • -archivelogs
    Specifies the archive log files.
  • -from-secondary -copy-id id
    Mounts the backup from secondary storage. If this option is not specified, SnapManager mounts the backup from primary storage. You can use this option if the backup is freed.
    You must specify the -copy-id option whenever you specify the -from-secondary option. If there is more than one backup on the secondary storage system, the -copy-id option is used to specify which backup copy on the secondary storage should be used to mount the backup.
    Note If you are using Data ONTAP operating in 7-Mode, you must specify a valid value for the -copy-id option. However, if you are using clustered Data ONTAP, the -copy-id option is not required.
  • -host host
    Specifies the host on which you want to mount the backup.
  • -dump
    Collects the dump files after the successful or failed mount operation.
  • -quiet
    Displays only error messages in the console. The default setting is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Note You must use this command only if you are using an external tool such as Oracle Recovery Manager (RMAN). SnapManager automatically handles the mounting of backups if you use the smsap backup restore command to restore the backup. This command displays a list, which shows the paths where the Snapshot copies have been mounted. This list is displayed only when the -verbose option is specified.
Example
The following example mounts the backup:
smsap backup mount -profile S10_BACKUP -label full_monthly_10 -verbose
SMSAP-13046 [INFO ]: Operation GUID 8abc013111b9088e0111b908a7560001
starting on Profile S10_BACKUP
SMSAP-08052 [INFO ]: Beginning to connect mount(s)
[/oracle/S10_mirrlogs, /oracle/S10_sapdata] from logical snapshot
SMSAP_S10_BACKUP_S10_F_C_1_8abc013111a450480111a45066210001.
SMSAP-08025 [INFO ]: Beginning to connect mount
/oracle/S10_mirrlogs from snapshot
SMSAP_S10_BACKUP_S10_F_C_1_8abc013111a450480111a45066210001_0 of
volume saplog_S10.
SMSAP-08027 [INFO ]: Finished connecting mount /oracle/S10_mirrlogs from snapshot
volume saplog_S10.
SMSAP-08025 [INFO ]: Beginning to connect mount /oracle/S10_sapdata
from snapshot
volume sapdata_S10.
SMSAP-08027 [INFO ]: Finished connecting mount /oracle/S10_sapdata
from snapshot
volume sapdata_S10.
SMSAP-08053 [INFO ]: Finished connecting mount(s)
SMSAP-13037 [INFO ]: Successfully completed operation: Backup Mount
SMSAP-13048 [INFO ]: Operation Status: SUCCESS
SMSAP-13049 [INFO ]: Elapsed Time: 0:01:00.981
Operation Id [8abc013111b9088e0111b908a7560001] succeeded.
