Prepare storage systems for SnapMirror replication
Before you can use SnapManager to mirror Snapshot copies, you need to configure a data-protection relationship between the source and destination volumes, then initialize the relationship. Upon initialization, SnapMirror makes a Snapshot copy of the source volume, then transfers the copy and all the data blocks that it references to the destination volume. It also transfers any other, less recent Snapshot copies on the source volume to the destination volume.
What you'll need
You must be a cluster administrator.
For Snapshot copy verification on the destination volume, the source and destination Storage Virtual Machines (SVMs) must have a management LIF as well as a data LIF.
The management LIF must have the same DNS name as the SVM. Set the management LIF role to data, the protocol to none, and the firewall policy to mgmt.
About this task
You can use the ONTAP command-line interface (CLI) or OnCommand System Manager to create a SnapMirror relationship. The following procedure documents CLI usage.
If you are storing database files and transaction logs on different volumes, you must create relationships between the source and destination volumes for the database files and between the source and destination volumes for the transaction logs. |
The following illustration shows the procedure for initializing a SnapMirror relationship:
Identify the destination cluster.
On the destination cluster, use the
volume createcommand with the-typeDP option to create a SnapMirror destination volume that is either the same or greater in size than the source volume.The language setting of the destination volume must match the language setting of the source volume. Example
The following command creates a 2 GB destination volume named dstvolB in SVM2 on the aggregate node01_aggr:
cluster2::> volume create -vserver SVM2 -volume dstvolB -aggregate node01_aggr -type DP -size 2GB
On the destination SVM, use the
snapmirror createcommand with the-type DPparameter to create a SnapMirror relationship.The DP type defines the relationship as a SnapMirror relationship.
Example
The following command creates a SnapMirror relationship between the source volume srcvolA on SVM1 and the destination volume dstvolB on SVM2, and assigns the default SnapMirror policy DPDefault:
SVM2::> snapmirror create -source-path SVM1:srcvolA -destination-path SVM2:dstvolB -type DP
Do not define a mirror schedule for the SnapMirror relationship. does that for you when you create a backup schedule. If you do not want to use the default SnapMirror policy, you can invoke the
snapmirror policy createcommand to define a SnapMirror policy. -
Use the
snapmirror initializecommand to initialize the relationship.The initialization process performs a baseline transfer to the destination volume. SnapMirror makes a Snapshot copy of the source volume, then transfers the copy and all the data blocks it references to the destination volume. It also transfers any other Snapshot copies on the source volume to the destination volume.
Example
The following command initializes the relationship between the source volume srcvolA on SVM1 and the destination volume dstvolB on SVM2:
SVM2::> snapmirror initialize -destination-path SVM2:dstvolB
Related information
