Running multiple parallel operations fails in SnapManager
When you run multiple parallel operations on separate databases that reside on the same storage system, the igroup for LUNs associated with both the databases might get deleted because of one of the operations. Later, if the other operation attempts to use the deleted igroup, SnapManager displays an error message.
For example, if you are running the backup delete and backup create operations on different databases almost at the same time, the backup create operation fails. The following sequential steps show what happens when you run backup delete and backup create operations on different databases almost at the same time.
Run the
backup deletecommand. -
Run the
backup createcommand. -
The
backup createcommand identifies the already existing igroup and uses the same igroup for mapping the LUN. -
The
backup deletecommand deletes the backup LUN, which was mapped to the same igroup. -
The
backup deletecommand then deletes the igroup because there are no LUNs associated with the igroup. -
The
backup createcommand creates the backup and tries to map to the igroup that does not exist, and therefore the operation fails.
What to do
You must create igroup for each storage system used by the database and use the following command to update SDU with the igroup information:
snapdrive igroup add
