SnapManager for SAP
Post rollback tasks
You must perform some additional steps after you rollback a repository database and downgrade the SnapManager host from SnapManager 3.2 to SnapManager 3.0, to view the schedules created in the earlier version of the repository database.
  1. Navigate to cd /opt/NetApp/smsap/repositories.
    The repositories directory might contain two files for each repository. The file name with the number sign (#) is created using SnapManager 3.1 or later and the file name with the hyphen (-) is created using the SnapManager 3.0.
    Example
    The file names might be as follows:
    • repository#SMSAP300a#SMSAPREPO1#10.72.197.141#1521
    • repository-smsap300a-smsaprepo1-10.72.197.141-1521
  2. Replace the number sign (#) in the file name with the hyphen (-).
    Example
    The file name that had the number sign (#), now contains hyphen (-): repository-SMSAP300a-SMSAPREPO1-10.72.197.141-1521.
