The smsap clone split-result command
Syntax
This command lets you view the result of the clone split process.
smsap clone split-result -profile profile [-host hostname] [-label split-label | -id split-id] [-quiet | -verbose]
-profile profileSpecifies the profile name of the clone.
-host hostnameSpecifies the hostname in which the clone exists.
-label split-labelSpecifies label name generated by clone split start process.
-id split-idSpecifies unique ID generated by clone split start process.
-quietDisplays only error messages on the console. The default is to display error and warning messages.
-verboseDisplays error, warning, and informational messages on the console.
