了解如何响应降级的ONTAP系统运行状况
贡献者 netapp-aaron-holt netapp-aherbin
通过查看因磁盘架缺少节点的两个路径而导致系统运行状况降级的具体示例,您可以查看在响应警报时命令行界面显示的内容。
启动 ONTAP 后,您将检查系统运行状况并发现状态为 degraded :
      cluster1::>system health status show
        Status
        degraded
您将显示警报以查明问题所在,并看到磁盘架 2 没有两个指向 node1 的路径:
      cluster1::>system health alert show
               Node: node1
           Resource: Shelf ID 2
           Severity: Major
	   Indication Time: Mon Nov 10 16:48:12 2013
     Probable Cause: Disk shelf 2 does not have two paths to controller
                     node1.
    Possible Effect: Access to disk shelf 2 via controller node1 will be
                     lost with a single hardware component failure (e.g.
                     cable, HBA, or IOM failure).
 Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2.
                     2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide.
                     3. Reboot the halted controllers.
                     4. Contact support personnel if the alert persists.
您可以显示有关警报的详细信息以获取更多信息,包括警报 ID :
      cluster1::>system health alert show -monitor node-connect -alert-id DualPathToDiskShelf_Alert -instance
                  Node: node1
               Monitor: node-connect
              Alert ID: DualPathToDiskShelf_Alert
     Alerting Resource: 50:05:0c:c1:02:00:0f:02
             Subsystem: SAS-connect
       Indication Time: Mon Mar 21 10:26:38 2011
    Perceived Severity: Major
        Probable Cause: Connection_establishment_error
           Description: Disk shelf 2 does not have two paths to controller node1.
       Possible Effect: Access to disk shelf 2 via controller node1 will be lost with a single
 hardware component failure (e.g. cable, HBA, or IOM failure).
           Acknowledge: false
              Suppress: false
                Policy: DualPathToDiskShelf_Policy
          Acknowledger: -
            Suppressor: -
Additional Information: Shelf uuid: 50:05:0c:c1:02:00:0f:02
                        Shelf id: 2
                        Shelf Name: 4d.shelf2
                        Number of Paths: 1
                        Number of Disks: 6
                        Adapter connected to IOMA:
                        Adapter connected to IOMB: 4d
Alerting Resource Name: Shelf ID 2
您确认警报以指示您正在处理该警报。
      cluster1::>system health alert modify -node node1 -alert-id DualPathToDiskShelf_Alert -acknowledge true
修复磁盘架 2 和节点 1 之间的布线,然后重新启动系统。然后、您再次检查系统运行状况、发现其状态为 OK:
        Status
        OK
