Quota management
Contributors netapp-ivanad
System Manager includes several features that help you to create, edit, or delete quotas. You can create a user, group, or tree quota and you can specify quota limits at the disk and file levels. All quotas are established on a per-volume basis.
After creating a quota, you can perform the following tasks:
  • Enable and disable quotas
  • Resize quotas
