Activating or deactivating quotas
Contributors netapp-ivanad
You can use System Manager to activate or deactivate quotas on one or more volumes that you select on your storage system. You can activate or deactivate quotas when you users and their storage requirements and limitations change.
Steps
  1. Click Storage > Quotas.
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which the quotas that you want to activate or deactivate reside.
  3. In the Quota Status on Volumes tab, select one or more volumes for which you want to activate or deactivate quotas.
  4. Click Activate or Deactivate, as required.
  5. If you are deactivating a quota, select the confirmation check box, and then click OK.
  6. Verify the quota status on the volumes in the Status column.
Related information
