Deleting IPspaces
Contributors netapp-ivanad
You can use System Manager to delete an IPspace when you no longer require the IPspace.
Before you begin
The IPspace that you want to delete must not be associated with any broadcast domains, network interfaces, peer relationships, or storage virtual machines (SVMs).
About this task
The system-defined “Default” IPspace and “Cluster” IPspace cannot be deleted.
Steps
  1. Click Network > IPspaces.
  2. Select the IPspace that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Yes.
