Deleting preferred domain controllers
Contributors netapp-ivanad
You can use System Manager to delete a preferred domain controller to which the storage virtual machine (SVM) computer account is associated. You can do this when you no longer want to use a particular domain controller.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Domain tab, select the domain that you want to delete from the Preferred Domain Controllers area, and then click Delete.
  4. Select the confirmation check box, and then click Delete.
