Disabling SAML authentication
Contributors netapp-ivanad
You can disable Security Assertion Markup Language (SAML) authentication if you want to disable remote access to System Manager, or to edit the SAML configuration.
About this task
Disabling SAML authentication does not delete SAML configuration.
Steps
  1. Click Configuration > Cluster > Authentication.
  2. Clear the Enable SAML authentication check box.
  3. Click Save.
    System Manager restarts.
  4. Log in to System Manager by using the cluster credentials.
Related information
