Editing active LDAP clients
Contributors netapp-ivanad
You can use System Manager to associate an active LDAP client with a storage virtual machine (SVM), which enables you to use LDAP as a name service or for name mapping.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click LDAP Configuration.
  4. In the LDAP Configuration window, click Edit.
  5. In the Active LDAP Client dialog box, select the LDAP client that you want to edit, and perform the following actions:
    • Modify the Active Directory domain servers.
    • Modify the preferred Active Directory servers.
  6. Click OK.
  7. Verify that the changes that you made are updated in the LDAP Configuration window.
