Editing default security settings
Contributors netapp-ivanad
You can use the Edit Default Security dialog box in System Manager to edit the default security settings for the iSCSI initiators that are connected to the storage system.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Protocols pane, click iSCSI.
  4. In the Default Security area of the Initiator Security tab, click Edit.
  5. In the Edit Default Security dialog box, change the security type.
    For CHAP authentication, you must provide the user name and password, and then confirm your password for inbound settings. For outbound settings, this login information is optional.
  6. Click OK.
Related information
