Editing efficiency policies
Contributors netapp-ivanad
You can use System Manager to modify the attributes of an efficiency policy such as the policy name, schedule name, and maximum runtime.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Policies pane, click Efficiency Policies.
  4. In the Efficiency Policies window, select the policy that you want to edit, and then click Edit.
  5. In the Edit Efficiency Policy dialog box, make the required changes.
  6. Click Save.
