Editing NIS domains
Contributors netapp-ivanad
You can use System Manager to modify NIS domains based on the requirement for storage virtual machine (SVM) authentication and authorization.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click NIS.
  4. Select the NIS domain, and then click Edit.
  5. Make the required changes, and then click Edit.
