Modifying export policy rules
Contributors netapp-ivanad
You can use System Manager to modify the specified client, access protocols, and access permissions of an export policy rule.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Policies pane, click Export Policies.
  4. In the Export Policies window, select the export policy for which you want to edit the export rule, and in the Export Rules tab, select the rule that you want to edit, and then click Edit.
  5. Modify the following parameters as required:
    • Client specification
    • Access protocols
    • Access details
  6. Click OK.
  7. Verify that the updated changes for the export rule are displayed in the Export Rules tab.
Related information
