Renaming export policies
Contributors netapp-ivanad
You can use System Managerto rename an existing export policy.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Policies pane, click Export Policies.
  4. Select the export policy that you want to rename, and then click Rename Policy.
  5. In the Rename Policy dialog box, specify a new policy name, and then click Modify.
  6. Verify the changes that you made in the Export Policies window.
