Guidelines for configuring ports on HP XP storage arrays
You should follow certain guidelines when configuring ports on HP XP storage arrays.
The guidelines for configuring ports on HP XP storage arrays are as follows:
You should add only one host group per port.
You should ensure that a host group includes all the FC initiator ports of the V-Series systems in an array LUN neighborhood.
