FC initiator ports required for connection to native disks
PDF of this doc site
Creating your file...
Your file is ready
You must connect a V-Series system to native disk shelves through the FC initiator ports. The number of initiator ports required for the connection depends on whether the V-Series system is a stand-alone system or in an HA pair.
The following table lists the required number of FC initiator ports for connecting a V-Series system to native disk shelves, depending on the system configuration:
Configuration | Number of FC initiator ports |
Stand-alone system |
HA pair |
