Requirements for configuring IBM XIV arrays with ONTAP systems
PDF of this doc site
Creating your file...
Your file is ready
Certain parameter settings are required on the storage array for the storage array to work successfully with ONTAP systems.
System parameter settings
The following table lists the system parameter settings for IBM XIV Gen3 arrays:
Parameter | Setting |
Default |
User-supplied host name |
User-supplied cluster name |
