Required Parameter settings on the storage array for ONTAP systems
PDF of this doc site
Creating your file...
Certain parameter settings are required on the storage array for the storage array to work successfully with ONTAP systems.
Required host channel director port configuration parameters
The host channel director port configuration parameters that must be set on the storage array are shown in the following table:
Parameter (names might differ between GUI and CLI) | Setting |
Enable |
Enable |
Enable |
Enable |
Enable |
Disable |
The Volume Set Addressing
parameter must be set the same way on all channel director ports to which the LUN is mapped. If the settings are different, ONTAP reports this as a LUN ID mismatch in storage errors show
output and in an EMS message.
Related information
