AutoSupport window
Contributors netapp-ivanad
The AutoSupport window enables you to view the current AutoSupport settings for your system. You can also change your system’s AutoSupport settings.
Command buttons
  • Enable
    Enables AutoSupport notification. Enable is the default.
  • Disable
    Disables AutoSupport notification.
  • Edit
    Opens the Edit AutoSupport Settings dialog box, which enables you to specify an email address from which email notifications are sent and to add multiple email addresses of the host names.
  • Test
    Opens the AutoSupport Test dialog box, which enables you to generate an AutoSupport test message.
  • AutoSupport Request
    Provides the following AutoSupport requests:
    • Generate AutoSupport
      Generates AutoSupport data for a selected node or all nodes.
    • View Previous Summary
      Displays the status and details of all the previous AutoSupport data.
  • Refresh
    Updates the information in the window.
Details area
The details area displays AutoSupport setting information such as the node name, AutoSupport status, transport protocol used, and name of the proxy server.
