Vss Requestor - Backup Components failed. Failed to call keep snapshot set.
Vss Requestor - Backup Components failed. Failed to call keep snapshot set. Reason Index and count must refer to a location within the string. -
This error occurs when VMs in a backup job reside on a Storage Virtual Machine and CIFS server with the same name.
Corrective action
None available for this release.
Failure example
Create a Storage Virtual Machine and CIFS server with the same name: for example, “test1”.
Add the test1 name to the DNS with both IP addresses.
On a Windows Server 2012 host, install SnapManager for Hyper-V and create some VMs using the CIFS shares from test1.
Create a backup copy that includes those VMs.
Note that the backup job fails with the error:
