透過ACL從來源儲存箱移轉CIFS資料至ONTAP 功能區
本節說明將CIFS資料與安全資訊從來源移轉至目標ONTAP 系統的逐步程序。
驗證目標ONTAP 系統是否健全。
C1_sti96-vsim-ucs540m_cluster::> cluster show Node Health Eligibility --------------------- ------- ------------ sti96-vsim-ucs540m true true sti96-vsim-ucs540n true true 2 entries were displayed. C1_sti96-vsim-ucs540m_cluster::> node show Node Health Eligibility Uptime Model Owner Location --------- ------ ----------- ------------- ----------- -------- --------------- sti96-vsim-ucs540m true true 15 days 21:17 SIMBOX ahammed sti sti96-vsim-ucs540n true true 15 days 21:17 SIMBOX ahammed sti 2 entries were displayed. cluster::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- sti96-vsim-ucs540m sti96-vsim- true Connected to sti96-vsim-ucs540n ucs540n sti96-vsim-ucs540n sti96-vsim- true Connected to sti96-vsim-ucs540m ucs540m 2 entries were displayed. C1_sti96-vsim-ucs540m_cluster::>
確認目標系統上至少存在一個非根Aggregate。Aggregate是正常的。
cluster::*> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ aggr0_sti96_vsim_ucs540o 7.58GB 373.3MB 95% online 1 sti96-vsim- raid_dp, ucs540o normal aggr0_sti96_vsim_ucs540p 7.58GB 373.3MB 95% online 1 sti96-vsim- raid_dp, ucs540p normal aggr_001 103.7GB 93.63GB 10% online 1 sti96-vsim- raid_dp, ucs540p normal sti96_vsim_ucs540o_aggr1 23.93GB 23.83GB 0% online 1 sti96-vsim- raid_dp, ucs540o normal sti96_vsim_ucs540p_aggr1 23.93GB 23.93GB 0% online 0 sti96-vsim- raid_dp, ucs540p normal 5 entries were displayed.
如果沒有資料Aggregate、請使用「shorage aggr create」命令建立新的集合體。 -
在目標叢集系統上建立SVM。
cluster::*> vserver create -vserver vs1 -rootvolume root_vs1 -aggregate sti96_vsim_ucs540o_aggr1 -rootvolume-security-style mixed Verify that the SVM was successfully created. C2_sti96-vsim-ucs540o_cluster::*> vserver show -vserver vs1 Vserver: vs1 Vserver Type: data Vserver Subtype: default Vserver UUID: f8bc54be-d91b-11e9-b99c-005056a7e57e Root Volume: root_vs1 Aggregate: sti96_vsim_ucs540o_aggr1 NIS Domain: NSQA-RTP-NIS1 Root Volume Security Style: mixed LDAP Client: esisconfig Default Volume Language Code: C.UTF-8 Snapshot Policy: default Data Services: data-nfs, data-cifs, data-flexcache, data-iscsi Comment: vs1 Quota Policy: default List of Aggregates Assigned: - Limit on Maximum Number of Volumes allowed: unlimited Vserver Admin State: running Vserver Operational State: running Vserver Operational State Stopped Reason: - Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp Disallowed Protocols: - Is Vserver with Infinite Volume: false QoS Policy Group: - Caching Policy Name: - Config Lock: false Volume Delete Retention Period: 0 IPspace Name: Default Foreground Process: - Is Msid Preserved for DR: false Force start required to start Destination in muliple IDP fan-out case: false Logical Space Reporting: false Logical Space Enforcement: false
在目的地SVM上建立新的讀寫資料磁碟區。確認安全樣式、語言設定和容量需求符合來源Volume。
CLUSTER CLUSTER::> vol create -vserver vs1 -volume dest_vol -aggregate aggr_001 -size 150g type RW -state online -security-style ntfs
建立資料LIF來處理SMB用戶端要求。
CLUSTER::> network interface create -vserver vs1 -lif sti96-vsim-ucs540o_data1 -address 10.237.165.87 -netmask 255.255.240.0 -role data -data-protocol nfs,cifs -home-node sti96-vsim-ucs540o -home-port e0d
確認LIF已成功建立。
cluster::*> network interface show -vserver vs1 Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- vs1 sti96-vsim-ucs540o_data1 up/up 10.237.165.87/20 sti96-vsim-ucs540o e0d true
如有需要、請使用SVM建立靜態路由。
Network route create -vserver dest -destination 0.0.0.0/0 -gateway 10.237.160.1
確認路由已成功建立。
cluster::*> network route show -vserver vs1 Vserver Destination Gateway Metric ------------------- --------------- --------------- ------ vs1 0.0.0.0/0 10.237.160.1 20 ::/0 fd20:8b1e:b255:9155::1 20 2 entries were displayed.
在SVM命名空間中掛載目標資料Volume。
CLUSTER::> volume mount -vserver vs1 -volume dest_vol -junction-path /dest_vol -active true
確認磁碟區已成功掛載。
cluster::*> volume show -vserver vs1 -fields junction-path vserver volume junction-path ------- -------- ------------- vs1 dest_vol /dest_vol vs1 root_vs1 / 2 entries were displayed. Note: You can also specify the volume mount options (junction path) with the volume create command.
在目標SVM上啟動CIFS服務。
cluster::*> vserver cifs start -vserver vs1 Warning: The admin status of the CIFS server for Vserver "vs1" is already "up".
確認服務已啟動並正在執行。
cluster::*> Verify the service is started and running C2_sti96-vsim-ucs540o_cluster::*> cifs show Server Status Domain/Workgroup Authentication Vserver Name Admin Name Style ----------- --------------- --------- ---------------- -------------- vs1 D60AB15C2AFC4D6 up CTL domain
確認預設匯出原則已套用至目標SVM。
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default
如有需要、請為目標SVM建立新的自訂匯出原則。
CLUSTER::> vserver export-policy create -vserver vs1 -policyname xcpexport
修改匯出原則規則、以允許存取CIFS用戶端。
CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0
確認原則規則已修改。
cluster::*> export-policy rule show -instance Vserver: vs1 Policy Name: default Rule Index: 1 Access Protocol: any List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0.0.0.0/0 RO Access Rule: any RW Access Rule: any User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: any Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true NTFS Unix Security Options: fail Vserver NTFS Unix Security Options: use_export_policy Change Ownership Mode: restricted Vserver Change Ownership Mode: use_export_policy Policy ID: 12884901889 Vserver: vs1 Policy Name: default Rule Index: 2 Access Protocol: any List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0:0:0:0:0:0:0:0/0 RO Access Rule: any RW Access Rule: any User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: none Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true NTFS Unix Security Options: fail Vserver NTFS Unix Security Options: use_export_policy Change Ownership Mode: restricted Vserver Change Ownership Mode: use_export_policy Policy ID: 12884901889 2 entries were displayed.
驗證是否允許用戶端存取磁碟區。
cluster::*> export-policy check-access -vserver vs1 -volume dest_vol -client-ip 10.234.17.81 -authentication-method none -protocol cifs -access-type read-write Policy Policy Rule Path Policy Owner Owner Type Index Access ----------------------------- ---------- --------- ---------- ------ ---------- / default root_vs1 volume 1 read /dest_vol default dest_vol volume 1 read-write 2 entries were displayed.
連線至安裝XCP的Windows用戶端系統。瀏覽至XCP安裝路徑。
C:\WRSHDNT>dir c:\netapp\xcp dir c:\netapp\xcp Volume in drive C has no label. Volume Serial Number is 5C04-C0C7 Directory of c:\netapp\xcp 09/18/2019 09:30 AM <DIR> . 09/18/2019 09:30 AM <DIR> .. 06/25/2019 06:27 AM 304 license 09/18/2019 09:30 AM <DIR> Logs 09/29/2019 08:45 PM 12,143,105 xcp.exe 2 File(s) 12,143,409 bytes 3 Dir(s) 29,219,549,184 bytes free
在XCP Windows用戶端主機系統上執行「XCP show」命令、查詢來源節點SMB匯出。
C:\WRSHDNT>c:\netapp\xcp\xcp show \\10.237.165.71 c:\netapp\xcp\xcp show \\10.237.165.71 XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 Shares Errors Server 6 0 10.237.165.71 == SMB Shares == Space Space Current Free Used Connections Share Path Folder Path 9.50GiB 4.57MiB 1 \\10.237.165.71\source_share C:\source_vol 94.3MiB 716KiB 0 \\10.237.165.71\ROOTSHARE C:\ 0 0 N/A \\10.237.165.71\ipc$ N/A 94.3MiB 716KiB 0 \\10.237.165.71\c$ C:\ == Attributes of SMB Shares == Share Types Remark source_share DISKTREE test share DISKTREE test_sh DISKTREE ROOTSHARE DISKTREE \"Share mapped to top of Vserver global namespace, created bydeux_init \" ipc$ PRINTQ,SPECIAL,IPC,DEVICE c$ SPECIAL == Permissions of SMB Shares == Share Entity Type source_share Everyone Allow/Full Control ROOTSHARE Everyone Allow/Full Control ipc$ Everyone Allow/Full Control c$ Administrators Allow/Full Control/
執行「help」命令進行複製。
C:\WRSHDNT>c:\netapp\xcp\xcp help copy c:\netapp\xcp\xcp help copy XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 usage: xcp copy [-h] [-v] [-parallel <n>] [-match <filter>] [-preserve-atime] [-acl] [-fallback-user FALLBACK_USER] [-fallback-group FALLBACK_GROUP] [-root] source target positional arguments: source target optional arguments: -h, --help show this help message and exit -v increase debug verbosity -parallel <n> number of concurrent processes (default: <cpu-count>) -match <filter> only process files and directories that match the filter (see `xcp help -match` for details) -preserve-atime restore last accessed date on source -acl copy security information -fallback-user FALLBACK_USER the name of the user on the target machine to receive the permissions of local (non-domain) source machine users (eg. domain\administrator) -fallback-group FALLBACK_GROUP the name of the group on the target machine to receive the permissions of local (non-domain) source machine groups (eg. domain\administrators) -root copy acl for root directorytxt
在目標ONTAP 系統上、取得您需要提供的本機使用者和本機群組名稱清單、作為「後援使用者」和「後援群組」引數路徑的值。
cluster::*> local-user show (vserver cifs users-and-groups local-user show) Vserver User Name Full Name Description ------------ --------------------------- -------------------- ------------- vs1 D60AB15C2AFC4D6\Administrator Built-in administrator account C2_sti96-vsim-ucs540o_cluster::*> local-group show (vserver cifs users-and-groups local-group show) Vserver Group Name Description -------------- -------------------------------- ---------------------------- vs1 BUILTIN\Administrators Built-in Administrators group vs1 BUILTIN\Backup Operators Backup Operators group vs1 BUILTIN\Guests Built-in Guests Group vs1 BUILTIN\Power Users Restricted administrative privileges vs1 BUILTIN\Users All users 5 entries were displayed
若要將CIFS資料與ACL從來源移轉至目標、請使用「-ACL」和「-fallback-user/group」選項來執行「XCP copy」命令。
對於「後援使用者/群組」選項、請指定Active Directory或本機使用者/群組中可找到的任何使用者或群組、以供目標系統使用。
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 8s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 13s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 18s ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 23s ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 28s 753 scanned, 0 errors, 0 skipped, 249 copied, 24.0KiB (4.82KiB/s), 33s 753 scanned, 0 errors, 0 skipped, 744 copied, 54.4KiB (6.07KiB/s), 38s 753 scanned, 0 errors, 0 skipped, 746 copied, 54.5KiB (20/s), 43s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (1.23KiB/s), 44s C:\WRSHDNT>
如果「XCP copy」產生錯誤訊息「錯誤無法取得後援安全性主體」、請在hosts檔案(「C:\Windows\System32\drivers\etc\hosts」)中新增目的地方塊。
請使用下列格式輸入NetApp儲存目的地Box。
<data vserver data interface ip> 1 or more white spaces <cifs server name>
cluster::*> cifs show Server Status Domain/Workgroup Authentication Vserver Name Admin Name Style ----------- --------------- --------- ---------------- -------------- vs1 D60AB15C2AFC4D6 up CTL domain C2_sti96-vsim-ucs540o_cluster::*> network interface show Logical Status Network Current Current Is Cluster sti96-vsim-ucs540p_clus1 up/up 192.168.148.136/24 sti96-vsim-ucs540p e0a true sti96-vsim-ucs540p_clus2 up/up 192.168.148.137/24 sti96-vsim-ucs540p e0b true vs1 sti96-vsim-ucs540o_data1 up/up 10.237.165.87/20 sti96-vsim-ucs540o e0d true sti96-vsim-ucs540o_data1_inet6 up/up fd20:8b1e:b255:9155::583/64 sti96-vsim-ucs540o e0d true sti96-vsim-ucs540o_data2 up/up 10.237.165.88/20 sti96-vsim-ucs540o e0e true 10.237.165.87 D60AB15C2AFC4D6 -> destination box entry to be added in hosts file.
如果您在主機檔案中新增目的地方塊項目後仍收到「錯誤無法取得後援安全性主體」錯誤訊息、則目標系統中不存在使用者/群組。
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\unknown_user -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\unknown_user -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 284 copied, 27.6KiB (5.54KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.44KiB/s), 22s C:\WRSHDNT>
使用「XCP copy」(XCP複本)、以ACL移轉CIFS資料(無論是否使用根資料夾)。
在沒有根資料夾的情況下、執行下列命令:
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 210 copied, 20.4KiB (4.08KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.38KiB/s), 22s C:\WRSHDNT>
使用root資料夾、執行下列命令:
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -root -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -root -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 243 copied, 23.6KiB (4.73KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (6.21KiB/s), 25s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 30s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 35s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 40s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 45s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 50s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 55s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m0s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m5s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (817/s), 1m8s C:\WRSHDNT>
